CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Oct 3, 2016 at 6:54 PM
    #5081
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Sooooooooo it rained yesterday and today for a bit...went to grab lunch with a buddy, got done, was standing in front of the truck and noticed my OEM driver headlight is effin misted over inside with condensation! TF is that crap! Guess I'm getting off my ass to do the retrofit finally
  2. Oct 3, 2016 at 7:07 PM
    #5082
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    This method worked great! Thanks again!
  3. Oct 4, 2016 at 10:07 AM
    #5083
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    It's pretty common for some very faint condensation to happen with any brand of headlights, no matter how expensive. The humidity levels inside/outside of the light basically just need to neutralize and it'll go away.
    110mm RGB will be a few months unfortunately. 4.0s are expected in stock later this week for backorders. Actual inventory a few weeks after that.
  4. Oct 4, 2016 at 10:09 AM
    #5084
    VolcomTacoma
    Jeff
    NorCal
    They are the OEM lights that came with the truck. Have had the truck for a year with zero issues and through a rainy season lol, no condensation. I'm guessing I cracked the housing somewhere or popped the seal a hair somewhere from mashing it in the sand to much. And it's only that one side...all the seals around the lights on the back look fine with no cracking.
  5. Oct 4, 2016 at 10:11 AM
    #5085
    TRSAndrew
    ATL
    Could potentially be as easy as the rubber seal even being slightly loose on the back of the housing, believe it or not.
  6. Oct 4, 2016 at 10:13 AM
    #5086
    VolcomTacoma
    Jeff
    NorCal
    Interesting. Well, regardless, I've got a set of Depo lights still in the box and a giant box of TRS retrofit stuff, both which have been on the shelf for like a year or so now lol, guess I better get around to it!
  7. Oct 4, 2016 at 11:11 AM
    #5087
    TaylorU
    Taylor
    Flagstaff, Arizona
    Fair warning, when removing the reflector bowl on the Depo brand head lights: the adjustment bolts were reverse threaded (on my set at least) so do not try to loosen them the normal way (counter-clockwise), otherwise you WILL break the little clips and won't be able to adjust your lights much when it comes time. Trust me. After months of being annoyed by very unequal and not high enough cutoffs, I finally reopened mine and ended up using the Depo clear plastic with the OEM housing and bowls etc.
  8. Oct 4, 2016 at 11:12 AM
    #5088
    VolcomTacoma
    Jeff
    NorCal
    Good to know! Thanks bud! :thumbsup:
    TaylorU[QUOTED] likes this.
  9. Oct 4, 2016 at 12:25 PM
    #5089
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Let me buy your kit before you use it. You don't need them. :spy:
    Btw, if anyone wants to upgrade to the 4.0's, I'll buy your 3.0's...for a fair price.
  10. Oct 4, 2016 at 1:13 PM
    #5090
    VolcomTacoma
    Jeff
    NorCal
    Or...not?
  11. Oct 4, 2016 at 1:14 PM
    #5091
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    It's ok man. They'll be in good hands.
  12. Oct 4, 2016 at 1:18 PM
    #5092
    VolcomTacoma
    Jeff
    NorCal
    Solid pass. I need moar light.
    rjsimz[QUOTED] likes this.
  13. Oct 4, 2016 at 2:26 PM
    #5093
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    If I ordered the D2S kit right now, will I get it with the backorder stock and have to wait until actual stock?
  14. Oct 4, 2016 at 4:51 PM
    #5094
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    TRSAndrew do you know when that Bluetooth is coming out for halos?
  15. Oct 5, 2016 at 6:42 AM
    #5095
    TRSAndrew
    ATL
    It wouldn't be in the first batch, so you'd unfortunately be waiting just a couple weeks. Definitely recommend ordering as early as possible though!
    I have the samples of the circuit boards and the cases in my hands, and I think they'll be entering production in the next few weeks. We definitely want them in hand by our busy season (starts with Thanksgiving).
    RexsTaco[QUOTED] likes this.
  16. Oct 6, 2016 at 6:33 PM
    #5096
    djtacoma
    djtacoma Active Member
    2014 Tacoma TRD Off Road DCSB
    Magnuson Supercharger, Cam gears, King 2.5 Coilovers and shocks, SPC UCAs, Icon progressive add-a-leaf, Wheelers u-bolt flip with Superbumps, Tom Woods one-piece driveshaft, TRD Pro wheels, 265/70/17 KO2s, air freshener
    Just ordered the Mini D2S 4.0 kit today for my 01 Tacoma! Will post up pics with output shots when they get installed.
    TRSJimmy and StevoNB like this.
  17. Oct 7, 2016 at 6:20 AM
    #5097
    TRSAndrew
    ATL
    Thanks for the business! Hopefully it makes the first batch, which we now expect in hand on Monday!
    TRSJimmy likes this.
  18. Oct 9, 2016 at 6:34 PM
    #5098
    TacoPretzel89
    TacoPretzel89 Well-Known Member
    '07 Tacoma
    So if I ordered the kit for the discount, I can't include the demon eyes into the code? I saw that 12-15s are getting a package deal with the Fogs and I was really hoping that would be made available for earlier 2nd gens?
  19. Oct 10, 2016 at 8:11 AM
    #5099
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    You should be able to use the code and add the demon eye to it. The discount will be towards D2S kits though. Let us know if that works!
  20. Oct 10, 2016 at 12:51 PM
    #5100
    TRSAndrew
    ATL
    Our inbound courier with the 4.0s screwed us because of the holiday, so we'll have the Mini D2S 4.0s tomorrow. Sorry for any who are affected by the delay!
