CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Dec 5, 2016 at 8:53 AM
    #5281
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Yes definitely
    trdmantiz[QUOTED] likes this.
  2. Dec 7, 2016 at 2:48 PM
    #5282
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I just want to say great service from TRS! Had a problem with the cyber Monday sale and they resolved the issue right away! Fast shipping and can't wait to get it all put together. Now to decide if I want to black out my headlights or color match... hmmm
  3. Dec 7, 2016 at 5:46 PM
    #5283
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Black the light housing then I'm not sure about the shroud
  4. Dec 7, 2016 at 6:06 PM
    #5284
    WildLand
    Josh
    NM
    16T4RSR54WD
    I haven't seen colormatched ones on first gens but probably wouldn't look as good as it does on a 2nd gen. I have extra lunar mist paint so I may try it? And if it looks bad I'll black it! What ever I do the housing, I'll do the shroud because I don't like the look of an eyeball.
    Did you use oven cleaner to get rid of the chrome?
  5. Dec 7, 2016 at 7:35 PM
    #5285
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Nope just wiped it down good and I think that was it. Then used high temp paint
    WildLand[QUOTED] likes this.
  6. Dec 8, 2016 at 4:45 PM
    #5286
    Santanero714
    Santanero714 Well-Known Member
    U can use steel wool on the chrome, itll make it better for the paint to grab. And ill recommend to paint the reflector black and the shroud with a different color of ur liking. that would look better. Just my two cents.
  7. Dec 8, 2016 at 5:45 PM
    #5287
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Oven cleaner and a red scuff pad will take the chrome right off. The red scuff pad preps it for primer too
    WildLand likes this.
  8. Dec 10, 2016 at 9:25 AM
    #5288
    WildLand
    Josh
    NM
    16T4RSR54WD
    Did the oven cleaner have any adverse affects on the stock sealant?
  9. Dec 10, 2016 at 9:58 AM
    #5289
    steveo27
    Pittsburgh
    Not sure. I removed all of it and redid It to be sure they sealed properly. The few hours spent removing all of it was worth knowing they wouldn't leak.
  10. Dec 11, 2016 at 9:30 AM
    #5290
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Anyone have any problems with their XB55 computers not sending power to the bulbs? I have power coming from the main ballast but nothing coming out the igniter side. On either of them
    Note: the high beam worked because I heard it clicking but the bulbs did not ignite still
  11. Dec 11, 2016 at 10:41 AM
    #5291
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Wish I would have known/thought of that. I would have ordered everything else on the Thanksgiving sale and picked up the brackets when they were available.... :(
    I see the RGB demon eyes are much cheaper now. Does that mean there is something better on the horizon to replace them?
  12. Dec 12, 2016 at 11:11 AM
    #5292
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Thanks for calling in Roman! I'm glad I can take care of you!
    Maybe ;)
  13. Dec 12, 2016 at 12:26 PM
    #5293
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Thanks! From the receipt, I have to send the old 55 ballasts and the bulb igniter wires together?
  14. Dec 12, 2016 at 1:04 PM
    #5294
    TRSJimmy
    Jimmy
    Gainesville, GA
    Just the igniter*
  15. Dec 17, 2016 at 2:18 PM
    #5295
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    Anyone have a great explanation for mounting/epoxying the shroud over the projector? Should I put epoxy on the outside rim of the projector?
    Trying to get this done by tomorrow night, don't have backup lights.
  16. Dec 17, 2016 at 2:30 PM
    #5296
    steveo27
    Pittsburgh
    I put JB Weld on the spots where the clips of the shroud met the projector and it worked out fine for me.
  17. Dec 17, 2016 at 3:22 PM
    #5297
    rjjencke
    Robbie
    Arizona
    The Apollo 3 does not have any clips that meet the shroud on the H1 from what I can see. The only place it meets is at the lip of the shroud and outer lip of the H1.
    I assume I must epoxy right there?
  18. Dec 17, 2016 at 3:39 PM
    #5298
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    You need centric rings
  19. Dec 17, 2016 at 9:59 PM
    #5299
    rjjencke
    Robbie
    Arizona
    Pretty sure I read that you don't 'need' a centric ring for certain shrouds/projectors etc. Additionally, my complete kit did not come with the centric rings. The Apollo 3 shrouds do slide on snuggly over the projectors.
    I think I'm going to put epoxy on the outside edge of the projectors and then slide on the shrouds, although this seems ballsy and scary. Any feedback would be excellent!!
  20. Dec 17, 2016 at 10:22 PM
    #5300
    steveo27
    Pittsburgh
    My Apollo 3s are JB Welded to my mini D2S's.
    They fit pretty snug but I hated the idea of them popping of and having to take the lights back apart to fix it. Better safe than sorry.
