CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Mar 16, 2017 at 10:59 AM
    #5601
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    No it was on its side. The lense discolored and the whole thing is clearly F'd
  2. Mar 16, 2017 at 11:07 AM
    #5602
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Did you turn off the oven? That's the only thing I can think that would cause it to melt that bad. Other than the not on cardboard or something
  3. Mar 16, 2017 at 11:11 AM
    #5603
    Perfuseme
    Rick
    Nah, did 7 minutes and was standing right there waiting...pissed
  4. Mar 16, 2017 at 11:34 AM
    #5604
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Only other thing I can think of is your oven temp is off. Mine is about 30 degrees higher than what I set it to. Had to buy a thermometer to read instead of the digital one
  5. Mar 16, 2017 at 11:38 AM
    #5605
    Perfuseme
    Rick
    Yeh it must be....passenger side I did first was fine
    WildLand[QUOTED] likes this.
  6. Mar 16, 2017 at 11:41 AM
    #5606
    BYJOSHCOOK
    Josh
    Check Out My Builds
    You're supposed to turn the oven off, then throw it in there
  7. Mar 16, 2017 at 11:46 AM
    #5607
    Perfuseme
    Rick
  8. Mar 16, 2017 at 11:58 AM
    #5608
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hmmm I was told/read to get it up to temp. Then turn off the oven and then set it in for 10 minutes. :notsure:
  9. Mar 16, 2017 at 12:01 PM
    #5609
    WildLand
    Josh
    NM
    16T4RSR54WD
    I left my oven on the whole time.
    I'm going to have to open them back up this weekend and replace the halos, might try the turning off method this time
    Perfuseme likes this.
  10. Mar 16, 2017 at 12:06 PM
    #5610
    Santanero714
    Santanero714 Well-Known Member
    I didnt do it like ur saying.
    I first letthe oven preheat at280 then tossed them in there with a plastic tray unde the headlight. I didnt turn off the oven. Waited 8 min and did turn off the oven then pull out the headlight. I did it like this a fews time cause i had to reopen my lights. And they are fine, didnt have an issue at all.
  11. Mar 16, 2017 at 12:34 PM
    #5611
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I do mine at 280 for 8 min for last 4-5 years and that's never happened
  12. Mar 16, 2017 at 12:38 PM
    #5612
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    My guess is the damaged side was the side the was facing down toward the bottom of the oven. And it was a combination of setting it directly on the rack and not using a piece of cardboard or a cookie sheet, and an oven that got too hot.
  13. Mar 16, 2017 at 1:19 PM
    #5613
    Perfuseme
    Rick
    Yeh, I'm definitely going to use less heat this next time.
  14. Mar 16, 2017 at 1:39 PM
    #5614
    LSC15
    Logan
    2008 TRD D-Cab
    I use cookie sheet with cardboard
  15. Mar 16, 2017 at 5:21 PM
    #5615
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    LOL.
    Christ.
    275*. Turn the oven off, then put the light in for about 10 minutes. Put it on a wooden cutting board. Check it half way through to make sure it doesnt turn into mush. Repeat as necessary
  16. Mar 16, 2017 at 6:31 PM
    #5616
    Perfuseme
    Rick
    Lesson learned
  17. Mar 19, 2017 at 2:43 PM
    #5617
    LSC15
    Logan
    2008 TRD D-Cab
    Dang man that sucks. Those halos are long gone lol. I would cut wires to those. Here is link to bulbs you need. Use code TRS10 to save you $5
    https://www.theretrofitsource.com/components/bulbs/d2s-morimoto-xb-hid.html
    Blackout14 likes this.
  18. Mar 19, 2017 at 2:44 PM
    #5618
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    High and low beams use the same bulb. The bulb is always the same intensity, the cutoff shield lowers to allow more light output for the high beams. Maybe it's the wired connection that is bad? If it's the solenoid for the high beam, you would probably have to take the headlight apart. Hopefully someone else with more troubleshooting experience can help.
  19. Mar 19, 2017 at 2:46 PM
    #5619
    LSC15
    Logan
    2008 TRD D-Cab
    If both low beams work then it's the solenoid on projector. Your bulb won't turn off on high but it wouldn't drop the cutoff to enable high beam
  20. Mar 19, 2017 at 2:48 PM
    #5620
    LSC15
    Logan
    2008 TRD D-Cab
    First check the high beam connection make sure it is clean and pins are locked in connectors. If that doesn't help then the solenoid is faulty on the projector
