CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Aug 27, 2013 at 7:01 PM
    #781
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Im not really sure how to do it yet but one of my buddies is gonna help me do it and when he does I will try to do a write up on it.
  2. Aug 27, 2013 at 7:49 PM
    #782
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Good thing about the mini kit is it is held in by a ring that sits down in slots, just like how the halogen bulb sits down in there. So there is very minimal room for the light cutoff to get horizontally off. As far as vertical, you just use the stock adjustments
  3. Aug 27, 2013 at 8:18 PM
    #783
    fenderpicks
    fenderpicks Well-Known Member
    I did want to get the MINI at first, but i saw posts about how the light would move around during driving. I dont want the light beam to be going up and down as i drive lol.
    THats when i decided to get the FX R.
    When i took off my reflector bowl, the factory adjusting bolts was just keep spinning, and wouldnt back out.... had to kind of pull on the bowl as i twist it with a ratcheting....
    is that what u are suppose to do?
  4. Aug 27, 2013 at 8:49 PM
    #784
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Aiming them is easy! I've got d2s and just did a set of d2s in a 95 but had to cut and jb weld those into his housings kinda impossible to not have them straight with the d2s and the alignment ring but I had to grind mine down cause 00 halogens come pre set with a tilt
  5. Aug 27, 2013 at 8:59 PM
    #785
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Got mine installed yesterday with the help of afroman
  6. Aug 27, 2013 at 9:56 PM
    #786
    SUMMIT556
    SUMMIT556 FCK Lightbars sponsor
    09 Tacoma SR5 4-cyl
    Bilstein 5100 front, FOX 2.0 remote resi rear, 2in add a leaf, OME 885 coils, magnaflow exhaust, LCE header, Toyo ATII 285/75/r16, fck lightbars, retrofit headlights and more.
    Ordered!!
  7. Aug 28, 2013 at 5:20 AM
    #787
    Delliam15
    Delliam15 Well-Known Member
    Irmo, SC
    2012 DCB PreRunner V6
    Led Interior Lights, HID Headlights and Fogs, Bed Lights, Bak Roll-X Tonneau, 2 10" Subwoofers, Electronic Pop-n-Lock Tailgate lock
    Say if I wanted to order three things from TRS could I make three separate orders and that count towards the 10?
    Anyone?
  8. Aug 28, 2013 at 5:23 AM
    #788
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah those screws just go into plastic so they don't always grab like they should. And yes the mini kit moves. Hard bumps seem to jar them and certain engine Rpms seem to shake them. My suspension is a more stiff then stock trucks so that may have something to do with it but the engine vibration shit really bothers me. I can't notice it at all unless I'm driving behind someone and can see my lights on another car but riding from outside my truck, the lights seem to constantly flicker. Especially when riding in a car where it seems that the light cut off line is close to the height of the car and I can watch it go in and out of the light, it seems to flicker constantly. It's very annoying to me. Seems that they could come up with a more secure mounting point or use a different kind/style of washer to hold the projector in. I think that washer is half the problem
  9. Aug 28, 2013 at 5:25 AM
    #789
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I'm gonna order mine today too ...
  10. Aug 28, 2013 at 6:43 AM
    #790
    fenderpicks
    I'm gonna place my order today too!!
    I already got started working on my extra headlights.....
    Took me apart, painted them, just no projectors to fit in lol
    PS: I emailed Andrew asking how many ppl is on the list, he told me there is only 2!!!!!
  11. Aug 28, 2013 at 8:32 AM
    #791
    fenderpicks
    U should definitely do that lol
  12. Aug 28, 2013 at 9:49 AM
    #792
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Good fuckin god! Well ...... I guess ill make 3 then
  13. Aug 28, 2013 at 10:18 AM
    #793
    fenderpicks
    Damit man, even if i place mine, we r still missing 6!!!!!
  14. Aug 28, 2013 at 10:22 AM
    #794
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    My gf just agreed to split the cost with me for my bday so I may be in soon too. Then we'd be halfway there.
  15. Aug 28, 2013 at 10:23 AM
    #795
    JTS2016TACO
    Jamie
    Chandler, AZ
    Once there is about 5 and people know it the next 5 hop on faster. No point in waiting they are taking on average about 2 weeks from what I have read on here
  16. Aug 28, 2013 at 10:25 AM
    #796
    fenderpicks
    COME ON BRO, get on board already!!!!!
    Whatever im placing my order.... i hope it goes out SOON.
    Because im super bored and would love to get started on my 2012 + Headlights
    Btw im trying to place an order now, but it is charging me for shipping?
    I thought it is free?
  17. Aug 28, 2013 at 10:31 AM
    #797
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Haha I need to. I've been lurking for the past 4 rounds of this..
    Andrew, if I do halos with the mini h1's are there different sized rings I need depending if I want to mount the inside or outside the shroud? I read there was a difference in another thread and wanted to ask you. I am planning on mounting the outside on the front of the shroud btw.
  18. Aug 28, 2013 at 10:45 AM
    #798
    geogecko
    geogecko Well-Known Member
    Broken Arrow, OK
    I read somewhere that you can only use one discount at a time. Shipping is only free if you don't use the group buy, or some other coupon. Still a lot better of a discount with the GB, versus $12-13 shipping.
    Think it depends on the shroud, so specify your shroud that you're planning on using.
  19. Aug 28, 2013 at 10:51 AM
    #799
    fenderpicks
    This is my config
    Bi-xenon FX-R Stage III Kit$315.00
    — Ballasts: Morimoto 3Five (35w)
    — Bulbs: Morimoto 3Five 5000K D2S
    — Halos: Yes, Morimoto XB LED (White)+$50.00
    — Projectors: LHD (2.5" lens)
    — Re-sealing Glue: Yes please+$10.00
    — Shrouds: Apollo 2.0
    — Wire Harness: Relay: H4/9003
  20. Aug 28, 2013 at 11:05 AM
    #800
    Delliam15
    Irmo, SC
    I'm ordering this afternoon. Imma try and split it up into two orders
