CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Oct 13, 2013 at 2:25 PM
    #1221
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's what I am running.
    They are the same 4300k burners used by the auto manufacturers.
  2. Oct 13, 2013 at 2:25 PM
    #1222
    Rich91710
    Rich
    Los Angeles
    08 Base
    What are you talking about?
  3. Oct 13, 2013 at 3:11 PM
    #1223
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    whats the best shroud to fit over the H1's to cover the projector the best?
    I've seen a few, apollo and gattling.I don't mine the fine tuning of the shrouds, just trying to find the one that requires the less cutting to sit almost factory against the headlight bowl.
  4. Oct 13, 2013 at 3:44 PM
    #1224
    Rich91710
    Rich
    Los Angeles
    08 Base
    Apollo on the D2S requires no trimming and you can't see the gap.
  5. Oct 13, 2013 at 9:37 PM
    #1225
    petrolhead
    petrolhead New Member
    Yes they are very good bulbs and well worth it. Just placed an order for them. Can't wait to start retrofitting the new ride!!
  6. Oct 14, 2013 at 6:05 PM
    #1226
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    Thinking of getting some. What wiring harness should I get with the D2S kit with the 3Five (35w) bulbs and ballasts?
  7. Oct 14, 2013 at 6:37 PM
    #1227
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
  8. Oct 14, 2013 at 6:59 PM
    #1228
    ToyotaKTMracing
    Shay
    West Virginia
    Thanks
  9. Oct 15, 2013 at 9:13 AM
    #1229
    madscientistmike
    madscientistmike Active Member
    Vancouver WA
    2010 TRD sport tacoma
    just placed my order for a set of mini H1's
    thanks!
  10. Oct 15, 2013 at 11:09 AM
    #1230
    PhatTaco12
    PhatTaco12 Well-Known Member
    Roseville, CA
    '12 DC 4X4 Off Road
    In progress
    Could be up to 7 or 8 now based on what I'm reading. Waiting sucks! Haha
  11. Oct 16, 2013 at 6:58 AM
    #1231
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    5 currently. Note: we will be closed tomorrow and Friday. Thanks guys!
  12. Oct 16, 2013 at 6:13 PM
    #1232
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    c'mon guys buy these kits up! haha
  13. Oct 18, 2013 at 10:58 AM
    #1233
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    :spy:
    Thinking of:
    Mini Stage III Kit (D2S) w/
    Morimoto 5Five (50w) D2S
    Morimoto 5Five 5000K D2S
    No halo rings, and Gatling Gun shrouds
  14. Oct 18, 2013 at 3:19 PM
    #1234
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    55w might be too much for the mini.....too much heat for that little projector
  15. Oct 18, 2013 at 3:52 PM
    #1235
    RelentlessFab
    Eric
    Sparks, NV
    Might, or will?
    I like light ;):D
  16. Oct 18, 2013 at 3:56 PM
    #1236
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Then get the Fx-r with 50watts ;)
  17. Oct 18, 2013 at 4:50 PM
    #1237
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    50W is too much ha, just helped another member put in FXRs and im about to get rid of my D2s for FXRs
  18. Oct 18, 2013 at 5:57 PM
    #1238
    Rich91710
    Rich
    Los Angeles
    08 Base
    Absolutely "will"
    It's way too much for the H1, and though some used to run them in the D2S, a couple of members have had issues with them melting the chrome off of the bowl.
    If you really need 55w (all of the OEM systems are 35w), then the FX-R is the only way to go.
  19. Oct 18, 2013 at 9:38 PM
    #1239
    AsianAnts
    AnT
    Yes, will :).
    I love light. Go fx-r and 55w! Hehe. But 35w will suffice as well :p surely an upgrade from stocks
  20. Oct 20, 2013 at 6:52 PM
    #1240
    SWCB
    SWCB I'd rather be fishing..
    james
    The Bayou, AL
    2012 Tacoma DCSB 4x4
    Debadged Future mods OME or FOX lift TRD CAI TRD exhaust TRD super charger Homer taco satoshi!!
    whats the diffrence between the Matsushita Gen V or Denso Slim
