CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Nov 24, 2013 at 9:16 PM
    #1541
    SantaCruzRunner
    SantaCruzRunner T4R Bay Area
    Andrew
    Sant cruz, Ca
    00 4Runner Limited
    when playing with mine, wiggling the connectors from the bulb and high beam to the ballast turns off the light.
  2. Nov 24, 2013 at 9:20 PM
    #1542
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It is a ballasted system, not continuous voltage.
    Someone recently posted concern about his ballast only outputting 8 volts... they don't run the lamps on low voltage DC.
    The ballast builds energy until there is enough to create an arc in the lamp. The output voltage then balances at what is needed to maintain the arc.
    Wiggling the connector on a hot lamp is messing with voltages in the area of 20,000 volts, high frequency.
    The lamp shutting off while messing with the connector, I would not be surprised that it requires a restart.
  3. Nov 24, 2013 at 9:43 PM
    #1543
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    No problems with mine yet, but then again I've only had mine turned on for a total of probably 20 minutes if that.
  4. Nov 25, 2013 at 6:42 AM
    #1544
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    from Nate @ TRS (found it on hidplanet.com), looks like the new ballasts ran into some bad parts
    Hi Guys,
    This has nothing to do with the relay harness at all, that part functions just fine. We believe that we have narrowed the problem down to the igniter in the ballast. There was some small part of the last batch of ballasts that have had issues with failure to ignite on the first strike. The problem has been fixed and those people that have reported problems will of course be getting replacements.
    Nate @ TRS
    (Posted a week ago)
    If you are having any issues with ballasts at all please make sure to give us a call 404-220-7940 or send us an email to answers@theretrofitsource.com with a brief description of your issue and your order details.
    In out last ballast shipment there was about 10-11% of the ballasts that are experiencing an issue with the igniter inside the ballast, which is causing the ballasts not to fire on the first attempt. Now that we know what the problem is and have a good way to test for it here this will not be an issue going forward. We are going to replace the ballasts of anyone that is having an issue.
    We really appreciate your patience why we get this all sorted!
    Nate @ TRS
    I spoke to Andrew this morning and the ETA for new ballast is Dec 10 according to him. Sucks that we have to wait couple more weeks again but at least we know that TRS is taking care of the problem and not running away from it. They are 100% backing their warranty and customer service!
  5. Nov 25, 2013 at 10:59 AM
    #1545
    SantaCruzRunner
    Andrew
    Sant cruz, Ca
    00 4Runner Limited
    Awesome. Im just glad to see I wasn't the only one with the problem lol. Will send them an email.
  6. Nov 25, 2013 at 4:01 PM
    #1546
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    i ordered a kit for my frs a few weeks ago. Both ballasts were bad. I emailed them and they sent me a very detailed description of whats wrong with the ballasts and stating that i could either wait till dec. 10th to receive the new ones or they would send me 2 of the same model ones but ones that would already have the problem fixed. After a few days of emails back and forth, they sent me 2 replacement ballasts of the same kind because i daily drive my car and need headlights. I opened that box up about an hour ago, plugged in the new ballasts and it took 4 times turning the switch on for 1 light to fire. Wait about 10 sec, do it again and nothing. Once again im stuck with 2 bad ballasts and no headlights. I cant wait to plug in my new FXR kit and see how well those ballasts work :rolleyes:
    Big fail for TRS at the moment. The only reason i say at the moment is my 3five ballasts in my truck right now have been excellent for 2 years. The only thing going for them currently is their excellent customer service. I wish i had some fucking working headlights though!!
  7. Nov 25, 2013 at 9:05 PM
    #1547
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    I want to do this and can't wait to have extra money. When you get the lights what do you have to hook up? I know I have to take my lights out an send them to you once i get the lights that are done. Correct or am I missing something.
  8. Nov 25, 2013 at 9:08 PM
    #1548
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    You are missing a lot it seems
  9. Nov 25, 2013 at 9:09 PM
    #1549
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
  10. Nov 27, 2013 at 6:27 AM
    #1550
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Admittedly there is a small percentage of a large batch of ballasts in circulation that have issues amplified by cold weather.
    With this generation of ballasts, we made the body slimmer and one drawback of that is the supplier used a smaller igniter unbeknownst to us. This is one of the issues.
    We also found that the flickering/pulsation in the ballasts is due to a design flaw in a circuit on the circuit board of the ballast.
    Both of these issues have been located and we currently have approx. 1,500 ballasts being built to the new specs just for the sake of replacing those effected. All future ballasts will adopt these features, but the ballasts in production right now are just for those with issues.
    We sincerely apologize for the issues which we just became aware of about a month ago and are working as quickly as possible to get each and every affected customer taken care of. We understand it's a massive inconvenience and we are very appreciative of your patience.
    We've never had an issue like this before and that's why it really took us by surprise.
  11. Nov 27, 2013 at 9:27 AM
    #1551
    slaphappy
    slaphappy Mama didn't raise no fool
    Travis
    River Valley
    Silver Fresco 2010 FJ Cruiser 4WD
    Is that why you guys put a stop to the group buy til sometime in 2014?
  12. Nov 27, 2013 at 11:56 AM
    #1552
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Got to it first.. that's what I was thinking was why they stopped after he posted that.
  13. Nov 27, 2013 at 12:38 PM
    #1553
    bellassaiw10
    Currituck NC
    Hope y'all are getting on their Black Friday sale ha I am
  14. Nov 27, 2013 at 12:40 PM
    #1554
    tacodane
    Dane
    What's sale is that
    edit: ya I'm down for the sale. Will be buying today just have to decide on shroud
  15. Nov 27, 2013 at 1:28 PM
    #1555
    fenderpicks
    fenderpicks Well-Known Member
    Anyone know what wiring harness u need to properly turn the xbled halo rings on and off?
  16. Nov 27, 2013 at 1:43 PM
    #1556
    tacodane
    Dane
    I think if you plan to have them cone on with dtrl or parking lights; you just splice the wires together
  17. Nov 27, 2013 at 1:49 PM
    #1557
    bellassaiw10
    Currituck NC
    Check out their Facebook page got the details, and yeah you have to splice the Xbs into something
  18. Nov 27, 2013 at 1:51 PM
    #1558
    fenderpicks
    Yea i know u can splice the existing wires.
    But if i get one of their harness i wouldn't have to do any splicing?
  19. Nov 27, 2013 at 1:53 PM
    #1559
    bellassaiw10
    Currituck NC
    Didn't know they made harnesses
  20. Nov 27, 2013 at 1:54 PM
    #1560
    tacodane
    Dane
    I think having a harness will be more Hassel. What I wanted was to connect the halos to a switch to turn them on when ever I want. But don't know how that would work
