CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Dec 7, 2013 at 11:02 AM
    #1741
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Apollo 3.0! I did like the 2.0 also but I like more of the gaps in the 3.0 shroud
  2. Dec 7, 2013 at 4:34 PM
    #1742
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Apollo 3.0? 2.0 is the "+" pattern with the flats top and bottom.... what is the 3.0?
  3. Dec 7, 2013 at 4:37 PM
    #1743
    tacodane
    Dane
  4. Dec 7, 2013 at 7:56 PM
    #1744
    InSight Retrofits
    InSight Retrofits Closed
    Outputs, love it
    6D25BA7A-F433-416C-B64A-EB2CE2DE9D31_zps_d0536b995ca7b55c71fab282c34a68a4085c36b0.jpg
    BA7CEE37-4188-4C47-82B7-59BB06D09E8A_zps_fd992778e84ef8f8c77609d93bfb7d5cb610a689.jpg
    A029088C-33BE-45AB-835D-55C519E0EF22_zps_17ee87eab43d9ffd0c34510814dcaa14d60e6f0a.jpg
    CFFFE0E6-FB6C-4D8C-8094-41B53E159753_zps_f1677da43264200a13eca4e7f667a7a9bd5c7884.jpg
    242EF039-562B-4C83-A9AD-7EFC6BF7082B_zps_42f5c7c11021c0a53d38d7bb580c64c04f0c83df.jpg
    8187C579-F3F8-427D-AFB7-2CBAC845A0E1_zps_6e08c1180d095b86e07bdabbd17db7aa150ed4cc.jpg
    73D98FB9-2F08-492F-9339-AEBE0002C91B_zps_ff9882ca4bde4ddfb4d438d8dc1b3a8a24167e7a.jpg
  5. Dec 7, 2013 at 8:57 PM
    #1745
    drapes97
    drapes97 Member
    andrew
    british columbia
    13 Toyota Tacoma Trd
    so i have ordered the fxr kit and i think it might have the bad ballasts. my question is that when i go to install them the ballasts will still work even if i have to turn the headlights on and off a few times? just because i need my truck for work and its dark every morning
  6. Dec 7, 2013 at 10:01 PM
    #1746
    Rich91710
    Rich
    Los Angeles
    08 Base
    The problem is not with every ballast, but yes, in general, if they don't light off at first, they will after cycling.
    If you are having trouble, use the test connector and go directly from the battery hot and ground to the ballast to confirm... grounds can be touchy on the Tacoma. I did not get a good ground from the radiator support.
  7. Dec 9, 2013 at 2:51 PM
    #1747
    98Tacoma
    98Tacoma Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    im planning on doing the Bi-xenon Morimoto Mini Stage III Kit (H1 xb35 5000k on my 1998 gen 1 tacoma. whats the best shourd for the mini just the standard mini gatling gun? also does anyone have a good write up for the gen 1 retro fit have found many gen 2 writes up i would guess they would be the same process just different lights
    was about to buy these buy decided to wait for the group buy when in 2014 will the group buys start up again?
  8. Dec 9, 2013 at 2:55 PM
    #1748
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Its pretty simple haha trust me once you start you'll be like uh duh
  9. Dec 9, 2013 at 2:57 PM
    #1749
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    TRS is a great company to deal with, amazing customer service and they stand behind there product! Thanks for the relay, it fixed my issue.
  10. Dec 9, 2013 at 3:15 PM
    #1750
    bellassaiw10
    Currituck NC
    Got my new relay today also
  11. Dec 9, 2013 at 3:35 PM
    #1751
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    yea ur probly right i found there youtube chanel and its very helpful. just wish the group buy was going on right now
  12. Dec 9, 2013 at 3:42 PM
    #1752
    bellassaiw10
    Currituck NC
    I bought mine outside of the GB it's worth it also if you use there Facebook code you can get 5% off
  13. Dec 9, 2013 at 11:39 PM
    #1753
    SantaCruzRunner
    SantaCruzRunner T4R Bay Area
    Andrew
    Sant cruz, Ca
    00 4Runner Limited
    So whats the status on these new ballasts....... getting kinda tired of my lights not turning on when I need them too....
  14. Dec 10, 2013 at 6:40 AM
    #1754
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    They should be in stock on December 17 and will be sent out ASAP.
  15. Dec 10, 2013 at 7:07 PM
    #1755
    SantaCruzRunner
    Andrew
    Sant cruz, Ca
    00 4Runner Limited
    sweet
  16. Dec 11, 2013 at 7:57 AM
    #1756
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    You should bench test all of them inside a freezer first.
  17. Dec 11, 2013 at 1:49 PM
    #1757
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I'm wanting to switch my retros to have my halo on outside but I don't want the gatling gun with it on the outside cuz it'll be too big looking in my housings. Should sale my whole setup and go with mini h1s so I can get mini gatling guns with XBs on the outside of shroud
  18. Dec 11, 2013 at 1:51 PM
    #1758
    tacodane
    Dane
    Why don't you just trade in your original halo?
  19. Dec 11, 2013 at 1:52 PM
    #1759
    LSC15
    Logan
    2008 TRD D-Cab
    My projector is jbwelded to housing and I don't want a halo on the outside of the Gatling Gun 2.0 cuz it will look to big
  20. Dec 11, 2013 at 1:53 PM
    #1760
    tacodane
    Dane
    The halo or the shroud?
