CLOSED - The Retrofit Source GB
Discussion in 'Automotive Group Buys' started by TRSAndrew, Feb 11, 2013.
  1. Dec 25, 2013 at 4:34 PM
    #1821
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    So I've been reading some things about the ballasts not firing up and flickering in the past few pages... What exactly is going on?
    My driver side sometimes wont fire up on first turn on, but will come on if I cycle the power again. Usually this happens when it's around freezing outside.
    Also, I've had the lights flicker as well since day 1.
    Anything I should be concerned about?
  2. Dec 25, 2013 at 4:36 PM
    #1822
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Should probably contact trs tomorrow ballast issue for sure with the lights not firing first go
  3. Dec 25, 2013 at 4:39 PM
    #1823
    geogecko
    geogecko Well-Known Member
    Broken Arrow, OK
    Yep, ballast could also be responsible for flickering, if you've got good grounds. The DSP models are supposed to correct that issue, and they do on mine.
  4. Dec 25, 2013 at 5:41 PM
    #1824
    Chad
    Chad
    Cary, NC
    After a while the flickering usually goes away. I've always assumed that was what the bulb did as it warmed up to full operating temp.
  5. Dec 25, 2013 at 6:12 PM
    #1825
    geogecko
    Broken Arrow, OK
    Mine never want away. It resembled the movement of a filament in a halogen light bulb.
    The couple seconds of flickering followed by color change, after start up, is normal.
  6. Dec 25, 2013 at 7:47 PM
    #1826
    Chad
    Chad
    Cary, NC
    Mine usually flickers for about 5 minutes before going away, or at least appearing to go away.
  7. Dec 26, 2013 at 10:09 AM
    #1827
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    just wondering, did you guys get any confirmation email or email about the replacement ballasts being shipped after sending the recall email to TRS?
  8. Dec 26, 2013 at 10:10 AM
    #1828
    tacodane
    Dane
    Yes they are suppose to send you an email plus get an email with the tracking number
  9. Dec 26, 2013 at 10:27 AM
    #1829
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    gotcha, thanks man. i'll be giving them a call right now
  10. Dec 26, 2013 at 10:34 AM
    #1830
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I emailed them and they had my name down for new ballasts but toes my email in wrong
  11. Dec 26, 2013 at 11:52 AM
    #1831
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    I called and they said that they aren't sending any email confirmation but he checked and said that they did get my recall email.
  12. Dec 26, 2013 at 12:26 PM
    #1832
    Chad
    Chad
    Cary, NC
    Recall email?
  13. Dec 26, 2013 at 12:42 PM
    #1833
    tacodane
    Dane
    I received an email from then that I'm receiving a package and a email from trs as a confirmation number
  14. Dec 26, 2013 at 4:36 PM
    #1834
    Chad
    Chad
    Cary, NC
    So if I'm experiencing the bad ballast systems just email them and they'll take care of it?
  15. Dec 26, 2013 at 4:44 PM
    #1835
    tacodane
    Dane
    Correct. Thought I was getting mine today but some how got my replacement bulb first when I called about the ballasts 3-4 before calling about my bulbs
  16. Dec 26, 2013 at 4:54 PM
    #1836
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    well damn i just found my email that they sent on dec. 12th. haha oh well, i got them the pics and info they need now so i guess its waiting time
  17. Dec 26, 2013 at 4:59 PM
    #1837
    tacodane
    Dane
    What pictures did you send them
  18. Dec 26, 2013 at 5:15 PM
    #1838
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    pics of the bad ballasts with both cables cut and the end type being used and pics of both of my original order slips
  19. Dec 26, 2013 at 5:16 PM
    #1839
    tacodane
    Dane
    But don't you still need to use those ballasts?
  20. Dec 26, 2013 at 5:30 PM
    #1840
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    hahahaha they dont work so i cant use them. lol
    lucky for me i have had a H1 kit in my tacoma for 2 years now with great working ballasts. I both a FXR kit for the truck and a H1 kit for my FRS and all the balllasts are bad so for goin on 6 weeks now, i have been switching the ballasts back and forth between vehicles.
