Closed Transmission System Opened by so-called mechanic
Discussion in 'Technical Chat' started by jhudson, Aug 11, 2013.
  1. Aug 11, 2013 at 10:00 AM
    jhudson
    jhudson [OP] New Member
    Mississippi
    2010 PreRunner
    It was opened briefly by a family member of mine who thought it was the oil pan drain plug. A small amount of fluid came out. Is this a problem?:eek:
  2. Aug 11, 2013 at 10:12 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Should not be a problem....just check the oil level and be sure that it is ok
