Closest thing to a Borla ATAK exhaust?
Discussion in 'Performance and Tuning' started by Frank4x4, Nov 15, 2020.
  1. Nov 15, 2020 at 12:13 PM
    Frank4x4
    Frank4x4 [OP] Member
    2019 White Tacoma OR
    2.5/1.5 suspension lift. 285/75/16 Nitto RG
    Hey all,
    looking at getting an aftermarket cat back. What’s the closest thing to a Borla Atak? I know it’s a 6 banger and not a V8. Suggestions anyone?
  2. Nov 15, 2020 at 12:19 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I would stick with oem .. every exhaust I have heard on this truck sounds bad . Drone . And sounds like a 4 banger .
    Slick Taco, Chew, Skydvrr and 4 others like this.
  3. Nov 15, 2020 at 12:34 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I have no idea what the aftermarket systems sound like. I do like the OEM system on my '06 TRD OR - subtle but noticeable. My new '21 TRD OR has a factory installed performance exhaust (aka cat back) - for the brief periods I've heard it, it sounds about the same (don't yet have the truck in my driveway). What I like about it is the durability (and the sound of course) - the '06 system is 14+ years old with no signs of issues, other than a gasket issue in front of the cat. Perhaps GOTSAND?18 knows more about the aftermarket stuff.
    The OEM system IS an expensive add-on at $800 - but what would you be paying for an aftermarket system in stainless steel?
  4. Nov 15, 2020 at 12:42 PM
    TRD__Chris
    TRD__Chris Well-Known Member
    STL
    2016 Sport
    The Borla ATAK is loud as shit. If you want something that annoying I’d look at MBRP.
    Most folks are going to suggest that you stay stock or try the TRD cat back system. All of the aftermarket exhausts I’ve heard on these trucks sounds like absolute doo-doo. Try doing some research on YouTube. Plenty of sound clips for you to compare and contrast.
  5. Nov 15, 2020 at 12:44 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    YouTube is better than nothing, but isn't good. Both your speakers and the microphone have limitations and cannot capture the true sounds.
  6. Nov 15, 2020 at 12:48 PM
    TRD__Chris
    STL
    2016 Sport
    Sounds like you need better better computer speakers :D
    All jokes aside, yes, you’re correct. Most of the clips are filmed with a cellphone so the sounds is going to be different than what you’ll experience in real life. However unless you can find a friend with the exhaust system installed on their truck I don’t think there are many other options.
    RedWings44[QUOTED] likes this.
  7. Nov 15, 2020 at 12:50 PM
    Frank4x4
    Lol, I heard the Atak on YouTube and thought it sounded great. MBRP sounded like trash when I looked it up.
  8. Nov 15, 2020 at 12:52 PM
    Frank4x4
    I have also looked at the black widow widow maker muffler. I might just keep it stock though
  9. Nov 15, 2020 at 12:58 PM
    RedWings44
    Michigan
    Pretty much. It's just a caveat to relying too much on YouTube. TFL tries it all the time and they all sound like tin cans from the video.
  10. Nov 15, 2020 at 1:15 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Skydvrr, Kev250R and Boghog1 like this.
  11. Nov 15, 2020 at 1:24 PM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    I've been given weird looks when I say this, buuuut, I actually like the way the TRD cat back sounds over stock. Like it enough to drop almost $1k on it? Maybe...I'll get a sport hood with a scoop before I get the exhaust.
    CT Yankee likes this.
  12. Nov 15, 2020 at 2:12 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Does Borla have an ATAK exhaust for the Tacoma?
    I have a Borla XS 1in2out, and I enjoy the sound and tone. Previously i had MBRP, and was fine until i got URDs ypipe and it became a raspy mess.
    DanishTaco likes this.
  13. Nov 15, 2020 at 2:41 PM
    Frank4x4
    They do not have the ATAK for the Tacoma
  14. Nov 15, 2020 at 7:02 PM
    CT Yankee
    CT
    Think about what you just stated. How many times for 1 rev does each cylinder fire?
    What difference does the angle between the cylinder banks make? None. 60 or 90, all cylinders fire once per rev.
    It's the firing of the cylinders that produce the sound and not the angle between the cylinder banks.
    Hobbs likes this.
  15. Nov 15, 2020 at 7:11 PM
    Oatwillie
    Oatwillie Well-Known Member
    Houston
    2021 TDR OR DCSB AT Concrete
    I didn't know this was a two stroke motor. (power/exhaust)
    4 stroke engines have a given cylinder fire every other revolution. (intake/compression/power/exhaust)
    Rainoffire and Hobbs like this.
  16. Nov 15, 2020 at 7:21 PM
    Rainoffire
    The angle of the V6 changes the timing for the firing pulse.
    90 degree V6 which share parts with V8 are usually 'odd fire' engines.
    Same reason as to why a 180° flat 6 sounds vastly different, because one bank mirrors the other side. Or a VR6 is technically a 10°-15° V6, also naturally sounds different.
  17. Nov 15, 2020 at 8:32 PM
    CT Yankee
    CT
    I stand corrected (doh). Nonetheless, the number of cylinders firing on each rev affects the exhaust.
    So are you telling me that 2 cylinders fire on one rev and 4 cylinders fire on the next? Or 2 cylinders every 3rd rev?
    As you can probably tell, I'm not an engine techno geek. Just applying what I think is common sense. Not afraid to admit my ignorance if I don't totally understand. My days of wrenching engines are a few decades behind me.
    Bottom line though - I like how my TRD OR (4.0) sounds with the OEM performance exhaust. Nice tone but not obnoxious. Same goes for my "soon to drive home" '21 TRD OR.
  18. Nov 15, 2020 at 8:53 PM
    Tacoma6MT
    Tacoma6MT Well-Known Member
    Oscar
    Bay Area
    2019 Cement DCSB O/R 6MT
    I have MBRP turndown and I think it sounds decent and in first or second gear you get some pops. Also I like that you can’t see it when standing behind the truck and better for off-roading since it is less likely to caught on something.
  19. Nov 15, 2020 at 9:15 PM
    solrchrgd
    solrchrgd Well-Known Member
    Torrance
    2019 CB Tacoma DC Offroad
  20. Nov 15, 2020 at 10:26 PM
    Rainoffire
    Usually the angle of the V would determine the optimal firing order of the cylinders.
    90 degrees between the cylinder banks have used a firing orders of R1-L2-R2-L3-L1-R3 or R1-L3-R3-L2-R2-L1. Several V6 engines with an angle of 60 degrees have used a firing order of R1-L1-R2-L2-R3-L3.
    This difference changes the pulse of exhaust and how it would flow through the system. 90°can have odd firing, which will give it more of a V8 with two dead cylinder sound.
    Oatwillie and Plain Jane Taco like this.
