cluch nice
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzz123, May 14, 2010.
  1. May 14, 2010 at 6:58 AM
    buzz123
    buzz123 [OP] New Member
    CT
    Tacoma 6-cyl
    I have 2003 Toyota Tacoma – 6-cylinder manual transmission, 4wheel.
    In last 1.5 year I have a problem with nice every time I press a clutch ( more when I release a clutch).
    I took my car to Toyota dealer twice they did something that it was OK for a while then the noise returned. Then I took it to Firestone Tire garage to change tires I told them about the problem. They told me that I need a new cylinder. I regret that I allowed them to change it - I am not sure that I got a quality cylinder.
    A few days ago I took it again to garage and mechanic took pedal assembly apart. It helped some, noise is not much. However I hear noise when pressing it close to the floor.
    I described the problem to mechanic, who works for the same company I do and does car work from his home/garage (he does a lot of work for my coworkers) and he told me right away over the phone that this is ‘throw out bearing problem..
    I have a feeling that he is right, any comments, anyone????
  2. May 14, 2010 at 7:01 AM
    YotaDude01
    YotaDude01 Kentucky Boy
    KY
    01' TRD off-road
    is it more of a squeek noise?
  3. May 14, 2010 at 7:03 AM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    It the noise is a squeak, it seems like it's a pretty common issue. Mine has squeaked since i bought it, i just turn the radio up, it isn't doing any harm.
  4. May 14, 2010 at 7:18 AM
    buzz123
    CT
    Tacoma 6-cyl
    yes. it is. It souns like old spring
  5. May 14, 2010 at 7:54 AM
    YotaDude01
    KY
    01' TRD off-road
  6. May 14, 2010 at 7:55 AM
    buzz123
    CT
    Tacoma 6-cyl
    changing TO bearing, will it help? Or I need to 'sit on it'
  7. May 14, 2010 at 7:56 AM
    YotaDude01
    KY
    01' TRD off-road
    yeah my 99 did that.. its common for them to do that.. it doesnt hurt anything that i know of. its just annoying... i wouldnt worry about it if its just a noise and you dont notice anything different while driving.
  8. May 14, 2010 at 8:45 AM
    scocar
    scocar Patron of the Farts
    Search for "clutch squeak" on this forum. It is a famous issue.
    One squeak comes from a crappy plastic bushing under the dash that breaks. The sound can be intermittent. You can replace the bushing or use another workaround. Search for detailed writeups on this forum.
    The other squeak, from under the truck (more like a creak sound), is from a pivot point on the clutch fork inside the transmission bell housing. This can't be lubed without removing the transmission, so ignore that until your clutch needs to be replaced.
  9. May 14, 2010 at 12:23 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    somehwat true. If its the creak coming from the transmission you can spray some white lithium grease on the throwout bearing from the rubber boot on the drivers side of the tranny. It alieves the problem for a while. Mine did this for almost 6 months, then my clutch went. I replaced the whole clutch assembly and the TO. 2 months after, the noise is back.
  10. May 14, 2010 at 12:49 PM
    scocar
    Huh. I heard it was specifically the pivot on the clutch release fork, and when I got under to look at listen right there at the rubber boot, it sure sounded like it, but I didn't want to go spraying a bunch of lube in there without knowing what it would hit.
    When you had it apart, did you lube this pivot point? I have never had it apart, but I examined the FSM diagrams. I don't even know how "lubeable" it is.
    Not that I have ever had a clutch assembly apart in my life...just trying to figure out the exact cause and solution.
  11. May 14, 2010 at 9:52 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i had the same squeek since day 1 up until i had the clutch replaced a few months ago, now no more squeek but who knows for how long...
