clucking noise when in idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., Jun 25, 2010.
  1. Jun 25, 2010 at 2:33 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    ok so when my truck is already warmed up, i hear a soft chug/ clucking noise. i dont know what it is but its soo annoying.
    any help? nthanks for ur time
  2. Jun 25, 2010 at 2:35 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  3. Jun 25, 2010 at 2:47 PM
    .Trdtaco315.
    Will
    Santa ana
    hmmmm lol
    well i used to be heavy on the gas bu ive changed my ways.
    should i just take it to toyota?
  4. Jun 25, 2010 at 3:20 PM
    Jester243
    Dan
    Spokane, WA
    does it sound more like say a belt, or pully? Does it get louder under acceleration?
  5. Jun 25, 2010 at 4:28 PM
    .Trdtaco315.
    Will
    Santa ana
    nope but its gets fast and softer when in idle.
  6. Jun 25, 2010 at 8:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've had two 3.4s and both have been "noisy" at idle. More of a tick, tick, tick depending on RPMs. I think they all do it.
    It might be annoying but it doesn't seem to be harmful. They keep running and running and running and.........
  7. Jun 26, 2010 at 4:54 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    I've had two 3.4's also, and just like yours both where noisy at idle. Like you said, tick, tick, tick. It's normal.
  8. Jun 26, 2010 at 5:00 AM
    calledin
    calledin Well-Known Member
    Mark
    Knoxville, TN
    2008 DC Sport SR5 4x4
    08 here. bought new. didnt do it at first but does it now? I just roll with it.
    I do have a little wine that sounds like its in the rear end when i let off the gas running 60-65 mph. you can let off gas and then give it just a little back and it starts to wine. also it starting to grind somewhere when i back out of driveway and turn to the left? Any Help??
  9. Jun 27, 2010 at 5:01 PM
    .Trdtaco315.
    Will
    Santa ana
    you know whats funny, is that i dont even here it anymore. i clean my k&n filter and it stoped makin that noise.
    off top, i totally kicked my friends 05 tacos ass. cruisin at 45 -55ish in 2nd. then floored it. he could keep up i left him about a car and a half behind!
  10. Dec 31, 2010 at 8:51 AM
    huskyking
    huskyking Active Member
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    I have an 03 3.4 SR5 mine makes a similar noise when warm and " when you take it out of Park and into Drive (with foot on brake) that is when it is most noticeable, does yours do same?
  11. Dec 31, 2010 at 12:50 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    Mine does the same thing. I thought at first it might be the timing belt or it needed the valves adjusted. Did both and nothing changed. My 4 cylinder made a similar noise too.
  12. Dec 31, 2010 at 12:59 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    haha i love the internet
  13. Jan 1, 2011 at 7:59 AM
    huskyking
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    good to see there is someone else out here with same thing, so have you been able to remedy the situation, if not have you been able to source the exact problem???
    thx
    Scott
    Happy New year
  14. Jan 1, 2011 at 6:08 PM
    calledin
    Mark
    Knoxville, TN
    We have a gas station that still sells 100% gas. I filled up with it and the ticking Stopped!!!!
    Gas SUCKS this day and time. 10-15 % ethel
  15. Jan 1, 2011 at 7:06 PM
    Miata Tech
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    I'm thinking it is most likely an intake resonance noise. Seems like it is pretty normal.
    Jim
  16. Jan 2, 2011 at 10:28 AM
    huskyking
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    thx Jim, guess it is one of those "live with" noises I 'll just cluck cluck, click click my way out of the driveway until i do not hear it Ha!!!!
    thx
