Clunk after stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inverno4, Jan 28, 2020.
  1. Jan 29, 2020 at 10:00 AM
    mindstar
    mindstar Well-Known Member
    BC Canada
    2017 TRD Off Road
    This happens to me too...dealer looked, nothing was wrong according to them.
    Junkhead likes this.
  2. Jan 29, 2020 at 10:05 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    cam bolts loose?
  3. Jan 29, 2020 at 10:15 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Brake slap?
  4. Jan 29, 2020 at 10:16 AM
    Inverno4
    Inverno4 [OP] Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    How do I check these?
  5. Jan 29, 2020 at 2:42 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Torque them down!
  6. Jan 29, 2020 at 5:05 PM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    Where are they located? Feels like it's right in the middle of the truck where the driveshaft is.
  7. Jan 29, 2020 at 6:34 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Is this clunk every time you stop? If I pull into my driveway and stop, no clunk. Back out of the driveway and stop, clunk. Pull forward and park on the street, clunk...
    I also noticed a clunk in the drive thru. If I'm inching forward and don't transition from gas to clutch smoothly... clunk. Annoying to me but nobody else at Taco Bell seems to care.
    AKGSD and watersoilair like this.
  8. Jan 29, 2020 at 8:16 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    On the inside of the lower control arms.. on the one up front you tighten the nut and on the rear one you tighten the bolt. both should be inside the U part of the control arm
  9. Jan 31, 2020 at 11:45 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Shocking.
    AKGSD and mindstar[QUOTED] like this.
  10. Jan 31, 2020 at 11:56 AM
    mindstar
    BC Canada
    2017 TRD Off Road
    Lol.... My brother in law is a mechanic, so I may get him to look at it. Trust him more than the dealer for sure :)
  11. Jan 31, 2020 at 11:58 AM
    CaliTaco718
    CaliTaco718 Instagram: socalmike9000
    Chapel HIll, TN
    2019 TRD Sport DCSB 4x4 MGM
    Falken AT4's.
    I get the same little knock when stopping and I was starting to think the same thing..
  12. Feb 7, 2020 at 11:31 AM
    CaliTaco718
    Chapel HIll, TN
    Falken AT4's.
    I just had a thought, It could also be the tranny shifting back into first gear as you come to a complete stop.
    CusterFan likes this.
  13. Feb 7, 2020 at 11:37 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Looks like he has a manual transmission.
  14. Feb 7, 2020 at 1:00 PM
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    I know you didn't do this but I had the same issue that was stupidly (actually beyond stupid) caused by me in this case. With 3000 miles on the truck I had to go to an event 4 miles down a dirt road in heavy rain. The next morning I jacked up the truck and took off each wheel and cleaned the dirt out of the backside of the rims and inside the fender wells (yes, I'll admit I'm anal about my ride). Long story short, I torqued all the lugs but the ones on the front driver's side. I kept hearing a low "chunk" on occasion when I would come to a stop. Took it to the dealer and the tech said, "I found your problem...the lugs on your front driver's side were not tight." I didn't admit to taking the rims off so they charged the labor to warranty. I always rotate my own tires but I damn sure have learned a valuable lesson!!
  15. Feb 7, 2020 at 1:14 PM
    #35
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    I get this clunk when I come to a stop. Only happens when the truck hasn't warmed up all the way. It feels like it comes from the rear. Same clunk you get if you parked on an incline and didn't use the handbrake. When you go from P to D, there's a transmission clunk.
  16. Feb 7, 2020 at 1:36 PM
    #36
    Hal_XIII
    Hal_XIII Well-Known Member
    Chicagoland
    19 Tacoma Trd O/R 4x4 S/B 6spd auto cav-blue
    Bilstein shocks & springs. Method 16in wheels Rigid led fogs 265/75 16 BFG KO2s
    Fuel in your tank splashing around, brother.
  17. Feb 7, 2020 at 2:02 PM
    #37
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    This clunk you are describing is a driveline clunk. It isn't from the transmission. The driveline loads up with the weight of the truck when parked on a hill. When you shift into drive the driveline unloads and then reloads. The clunk is from the play in the ring and pinion and in the slip yoke. It is a small clunk that gets amplified by the tube of the driveshaft. This also might be what the OP is hearing.
    I have a long wheel base Econoline Motorhome with a long driveshaft. The clunks from that driveline from park to drive or drive to reverse make the Tacoma driveline clunks minor at best. Nothing that I am concerned about. If the play isn't in the driveline for movement and heat expansion then things seize up and break.
  18. Feb 7, 2020 at 10:00 PM
    #38
    High Desert Yota
    High Desert Yota New Member
    Northern Nevada
    2020 SR 4x4
    2020 SR. Mine does this too. Not on every stop. Maybe once or twice a day during a 25 mile trip. Test drove other Tacomas before buying this one and noticed same sound. Figured it was normal.
  19. Feb 8, 2020 at 5:41 AM
    #39
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I drove a 2003 Dodge Dakota for 13 years with a clunk like you are descending. I just got use to hearing it.
  20. Feb 8, 2020 at 5:44 AM
    #40
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    But then you have no pen
    Speedfreak[QUOTED] likes this.
