Clunk coming from suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Apr 25, 2021.
  1. Apr 28, 2021 at 1:58 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  2. Apr 28, 2021 at 2:09 PM
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
  3. Apr 28, 2021 at 2:28 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Oh, that was 6 years ago and still (two suspension shops visits, and new springs installed) have never figured it out... The new spring installed did lessen the frequency of it but still happens once and a while.
  4. Apr 28, 2021 at 2:32 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    I have the same/similar sound. I should be getting some suspension work done soon. possibly new shocks, and changing the LBJs. I'll post up if that fixes it. In the meantime I'm watching to see if what fixes it for you.
  5. Apr 28, 2021 at 2:37 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Don't laugh.....try greasing the hood striker latch. No WD40....actual grease. You would be surprised how that noise can sound just like something in the front suspension.
    Not saying this is everyone's issue. But it might help a couple of you
    KingTaco81 likes this.
  6. Apr 28, 2021 at 2:39 PM
    OvrlandTaco
    OvrlandTaco IG: Ovrlandtaco
    Colton
    Wyoming/Texas
    '06 Black DCSB TRD Off-Road
    I was having a front-end clunk in my truck for months and practically replaced my entire front end before I found out I just had a blown shock. The best bet is to try and find a reputable shop that will help you find the problem.
  7. Apr 28, 2021 at 3:43 PM
    p16
    Yeah if I am unable to diagnose the problem myself I might just take it into the shop. I don’t want to waste all of my time and money trying to figure it out part by part
  8. Apr 28, 2021 at 3:44 PM
    p16
    Ok I’ll check that out lol
  9. Apr 28, 2021 at 4:12 PM
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    +1 this has happened to me more than once now
  10. May 13, 2021 at 11:56 AM
    p16
    Does anyone think it could be the top hat assembly bolt on top of my coils. If so does anyone know the torque to it I can’t find it anywhere? I have the yellow bilsteins all around.
  11. May 13, 2021 at 12:35 PM
    Jacuna_20
    Jacuna_20 New Member
    Jesus
    2011 Tacoma prerunner
    Bilstiens 5100
    Damn I hear a clunk on mine too .... I just installed 4 inch lift spindles and a 1.5 block in the rear. And I hear a clunk when going on bumps or something as simple as pulling out of my driving when both tires fall into the little dip houses have on their driveway it clanks ...
  12. May 13, 2021 at 3:05 PM
    p16
    Maybe it’s your upper control arms hitting your coils?
  13. May 13, 2021 at 3:10 PM
    Jacuna_20
    Jesus
    Bilstiens 5100
    I actually just got back from the mechanic shop turn out my LCA bushings are cracked and the uniball has grease all out.. time to replace them LCA. Any recommendations on a budget friendly brand not too cheap nor too pricey
    Thanks
  14. May 13, 2021 at 11:22 PM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    I tried to tell you but you weren’t listening, therefore I have no recommendations.... OEM
  15. May 18, 2021 at 10:09 AM
    #35
    DarthPow
    So I got my Tie Rods (inner and outer) and entirely new LCAs on my truck, and after a day of driving, I haven't heard the clunking yet. I think the tie rods, LCAs, and the sway bar are the most likely culprits for this sound, so if I hear it again, I'll check my sway bar. But so far I think that work has solved the problem for me.
    Turdyota3000 likes this.
  16. May 18, 2021 at 10:25 AM
    #36
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    I replaced with Moog LCA's a while ago, which saved cost over OEM, and i'm going to put Whiteline bushings in my factory LCA's for when the Moog's wear out.
    The Moog's fixed my steering wheel shake and vibe because my OEM bushings were toast. Worked out well for me.
    You could just swap out the bushings and ball joint of your OEM LCA's instead of buying whole new arms. Lots of bushing & ball joint options out there. Just need access to a hydraulic press.
  17. May 18, 2021 at 11:27 AM
    #37
    DarthPow
    mine were replaced with Moog as well.
  18. Apr 22, 2024 at 12:06 AM
    #38
    p16
    same here. Changed lcas and outer tie rods and clunk has seemed to have gone away
    Relaxinslax likes this.
