Clunk disappeared after replacing both front axle assemblies?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Underscore, Apr 21, 2015.
  1. Apr 21, 2015 at 5:02 AM
    Underscore
    Underscore [OP] Active Member
    portland CT
    TRD 3.4l
    So I'd developed a front end clunk going over medium/large bumps in the last few weeks. When I first went to check it out I noticed that both lower CV boots had blown (not surprised, they were old to begin with and then I lifted the truck) but couldn't find anything that could be causing the clunk. Except maybe the LBJs, which seem a little loose but I had nothing to compare it to.
    I figured I'd check it out further when replacing the axle assemblies. Still couldn't find anything. I greased the stuff that needed greasing, axles went in fine, I put it all back together, drove it over some bumpy stuff, and the clunk is gone. Clunk is still gone 100 miles later.
    I didn't think worn CVs clunked over bumps. Any of you have any ideas?
    Thanks in advance for any replies.
  2. Apr 21, 2015 at 9:58 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    They will pop and/or clunk if they are going out in my experience.
  3. Apr 21, 2015 at 10:05 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^This is true.
    Did they pop when you were going straight or only around corners? (especially tight ones, like backing into a parking spot)
  4. Apr 21, 2015 at 11:14 AM
    Underscore
    portland CT
    TRD 3.4l
    See, this is what I thought distinguished a bad CV noise from the other things that could be wrong. If whatever clunky thing happens exclusively, or just worse when you turn, then it's likely the CVs. If it just happens over bumps, it's probably something else.
    This noise had nothing to do with whether I was turning or not, it only happened when the suspension was working.
    I'm thinking maybe the worn joints threw the front end beyond its tolerances and stressed something that's wearing but not worn so bad yet.
    Or, it was just bitched up CVs making noises.
    I'm just trying to figure out whether I have an issue I should be addressing here or if I'm just being paranoid because I had it in my head that swapping the axles wouldn't fix the clunk, and then it did.
  5. Apr 22, 2015 at 7:33 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Good thing is you can check the ball joints. CV's are harder to check. Start with the ball joints, they are relatively cheap too. Then move to CV's. I ended up doing that after my lift. UBJ's were very loose. CV's were bad too. Boot tore and I pushed it...
  6. Apr 22, 2015 at 8:16 AM
    Underscore
    portland CT
    TRD 3.4l
    I replaced the axle assemblies and the clunk went away, I'm just wondering if I have a problem still. Like something that's worn out and only clunked when the CVs were worn because the tolerances changed.
  7. Sep 3, 2015 at 9:13 AM
    cartinfan
    cartinfan New Member
    Jay
    2002 Tacoma 4dr 4x4
    2 inch lift
    My clunk came from a bad carrier bearing. Changed the u joints just because you have to pull the drive shaft .
