clunk from front after 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sal C, Feb 17, 2011.
  1. Feb 17, 2011 at 3:45 PM
    Sal C
    Sal C [OP] Member
    Az
    brand new
    nothing yet
    Got a 2010 V6 taco TRD. When slowing down (or stopping) to put her in 4WD, she does fine. When I switch back into 2 WD, it takes a second, then I hear (and feel) a distinct 'clunk' from the front. Just turned 12K miles on her, but I don't ever remember this until recently. Also, when I am in 4WD, turning the wheels all the way to either side and then I let the clutch out, the front wheels seem to be in a 'diff-lock' mode. In other words, one of the front wheels will be skidding a little...like the rears do when locked in. When one is in 4WD, that doesn't diff lock the front axle does it?
    Any help appreciated
  2. Feb 17, 2011 at 3:48 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    are you doing this on highway?? turning while in 4wd will cause it to bind. that's a no-no.
    the clunk is the 4wd disengaging....
    both are normal and one is wrong.
  3. Feb 17, 2011 at 3:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Its all normal for 4wd. The clunk is it disengaging.
  4. Feb 17, 2011 at 3:52 PM
    dpascual1986
    dpascual1986 Well-Known Member
    dude, its normal to hear a "clunk" when disengaging 4wd when you are stopped, try disengaging at above 30mph, the "clunk" should be gone.
    when in 4wd, steering will feel like it is limited -its normal. Youre not supposed to be 4wd on the pavement anyway (I assume youre on pavement, you will not "skid" on loose gravel, sand or mud). When in 4wd on the mud, gravel or sand, then it will feel much better.
  5. Feb 17, 2011 at 4:14 PM
    dpascual1986
    umm... your dad was sold a 4x4 placebo?
  6. Feb 17, 2011 at 4:24 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Mine does that too. It's normal. Sometime it disengages without making that sound though. Always put it in neutral first, at least that's what I do.
  7. Feb 17, 2011 at 5:14 PM
    Sal C
    Sal C [OP] Member
    Az
    brand new
    nothing yet
    thanks for all the replies so quickly. I had pulled out my boat from my back yard (dirt), then on to pavement. That was when I realized I was in 4wd. Then I immediately switched to 2 wd. I don't make a habit of 4 wd on pavement.I;ll try a couple of the other suggestions also. Isn't 30 mph pretty fast to be going in 4 WD?
  8. Feb 17, 2011 at 5:16 PM
    S.B.
    Sean
    I've done 80mph in 4wd. But that was soft dirt/sand.
  9. Feb 17, 2011 at 5:18 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Mine as well. I also flip into neutral if i remember or can just to take any pressure of things when disengaging. Definitely 4x4 on dry clean blacktop = bad.
    I have pulled the trailer out of the back yard and ended up on drive way in 4x4 and yes clunk when disengage. OOPS
