Clunk from front end while backing up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DigB, Jul 12, 2012.
  1. Jul 12, 2012 at 4:44 PM
    DigB
    DigB [OP] Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    So while backing up yesterday I noticed a mild clunk from the front drivers side of my truck. Its only happened a few times and all fairly recently. Yesterday I was backing out of a driveway with my wheels turned to the right and I went over a small bump at the end of a driveway. I haven't noticed anything else out of the ordinary. The steering seems tight, when I go forward over a bump there aren't any clunks and the truck doesn't wander on the road. I haven't noticed anything when I hit the brakes except for a SMALL ?"bump"? :notsure: when I come to a complete stop. My first thought is that the ball joints on the front drivers side are loose... I had the similar sensation while coming to a stop in an old car of mine when the ball joints needed replacing. I hope this isn't a big issue.....not too much money around for repairs right now!
  2. Jul 12, 2012 at 4:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Brake pads shifting inside the calipers.
  3. Jul 12, 2012 at 5:03 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Due to needing replacement?
  4. Jul 12, 2012 at 5:15 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    No. The brake pads by design are slightly narrower than the channel in the caliper, so they move up and down when you apply brakes after changing direction.
  5. Jul 12, 2012 at 5:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This. Normal.
  6. Jul 12, 2012 at 6:01 PM
    RyanK1
    RyanK1 Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    Check the lower a-arm bolts, I had the same problem a while back, I think the specs are 110 ftlbs
  7. Jul 12, 2012 at 6:32 PM
    myname150
    myname150 Well-Known Member
    This ^
    Mine have done this since I first got my truck, or near then.
  8. Jul 12, 2012 at 6:37 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if it's jsut a small clicking, then i agree it's the brake pads shifting. however, if it's anyting more than a click, if you can feel it in the steering wheel of seat, it may be your balljoints. i had a nice big clunk coming from my passengers side when i hit the brakes while turning in reverse. new upper control arm ball joints (for the light racing arms) and no more clunk. after taking out the old ball joints, it was clear that that was the issue.
    good luck determining what's making the noise.
  9. Jul 13, 2012 at 2:36 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    I never knew this, good to know!
    I have a feeling its something to do with the ball joints or A-arms...it was way too loud to be normal, My fiancee, who is not a gear head, even heard the noise and wondered what it was.
    KOTOC79 and CASHORT like this.
  10. Jul 23, 2012 at 3:25 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Noone mentioned CV Joint? I've had the exact symptom (on a non-taco) that needed CV's.
  11. Jul 23, 2012 at 4:17 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    The brake pads sliding back and forth is a loud click style sound.
    If you are getting a louder or deeper sound that is a thud or can be felt it is likely driveline or suspension related.
  12. Jul 31, 2012 at 2:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have a slight clunk on passenger side... you can only feel it while sitting in the passenger seat and on the highway. A mild clunk.... sporadically ... no bumps in the road, no braking, no turning.....just driving on the highway. It's not brake pads (I have that clunk too and know what it is).
    I've gotta get under there and look around. My husband swears its ball joints but the roadways are smooth. I'll cringe at the thought of CV's.... with only 50K miles on the truck and NO offroad abuse...??
  13. Feb 25, 2013 at 5:22 PM
    tundrataco
    tundrataco Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    i have just started to get the same click, ive only owned the 07 with 90 000 KMS on it for 3 weeks, week 2 i installed billies and rear aal. didnt notice the loud click until the 3rd week. dont see anything loose, it only happens when almost completely stopped, foot on brake, and switching from fwd to rev or the opposite. but its not driveline, im sure of that, brake pads make sense, i never feel it in the steering wheel either..
  14. Feb 25, 2013 at 6:20 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I recently installed new coil-overs, upper control arms, outer tie rod ends, and lower ball joints all at once. After a couple days my front end began popping and clanking when turning the wheel while either stopped or moving at slow speeds. After a lot off digging around I found all four lower control arm bolts (two each side, straddling the lower ball joint) loose. I tightened w/ blue Loctite and no more noises!
    By the way, my brake pads click/clank when first applying the brakes after changing direction forward/reverse. Didn't begin doing it until after 45,000 miles and six years of driving.
  15. Feb 25, 2013 at 7:09 PM
    RyanK1
    I had just recently installed 5100's and noticed the sound after the alignment was done. I had a friend stand outside the drivers side of the truck while I drove over a 2x4 with the wheels full lock to the passenger side. He could physically see the movement. We torqued them to spec and havent had a problem since.
  16. Feb 25, 2013 at 7:28 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    Mine had the clunk as well, took it to dealer and they showed me how the brake pads shift making the clunk sound. Only on driver side, too.
  17. Jan 26, 2014 at 11:24 AM
    Chargin18
    Chargin18 Adult Member
    Charlie
    Salisbury, NC
    07' Regular cab DeBadged
    Stereo system, off-road lights, roll bar, HID kits, Hyperion Led Bar, 3 inch lift, custom satoshi grill, 31 10.50/R15, black rims, 5% tint, custom built headlights. paint matched grill, 1.25" wheel adapters.
    my truck did that when the strut bushing tore and the strut was loose at the top. it was the strut sliding forward and backward. 2007 2wd Tacoma reg cab
