Clunk from park to reverse. Any thoughts on what this could be are appreciated!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Johnfeb94, Jun 13, 2018.
  1. Jun 13, 2018 at 5:04 PM
    Johnfeb94
    Johnfeb94 [OP] Member
    Johnathan
    2016 White Tacoma SR5 L4 4x2
    Aftermarket stereo system
    https://youtu.be/JizMiaX8i6Q - Transmission to drive shaft
    https://youtu.be/s8ygnv8BCHY - Rear diff to drive shaft
    Truck is 2016 4x2 102k miles. When watching both clips the sound is more prominent from the rear. Only happens in park to reverse. I noticed that by letting off the brake at the right time it doesn't clunk. It also only will do this on cold starts, doesn't do it at all when it's warm.
    I'm taking it to the shop to be looked at tomorrow but any input would be helpful. Thank you!
    Tibetan Nomad and siznarf like this.
  2. Jun 13, 2018 at 5:43 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    If universal joints are good then... excessive backlash between ring and pinion or excessive spider gear wear either way sounds like the rear end is worn out! Using the wrong gear oil would cause premature wear.
    Johnfeb94[OP] likes this.
  3. Jun 13, 2018 at 6:39 PM
    Johnfeb94
    Johnathan
    I’m going to expect the worst and guess that it is the rear end. Do you think changing the diff fluid could help?
  4. Jun 13, 2018 at 6:55 PM
    Speeed
    Speeed Member
    Flavio
    2018 Tacoma OR AWD
    Stock for now
    I'm always (when going to park) put the car/truck in neutral, hand brake then parking.
    never had a clunk.
