Clunk from rear end over bumps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nonfatwater7, Nov 17, 2011.
  1. Nov 17, 2011 at 8:37 PM
    Nonfatwater7
    Nonfatwater7 [OP] Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    Can't figure this out...
    It is literally killing me, I can't stand it. I just put in 5100's in the front. Haven't had the rear end apart in about 9 months and it hasnt made this sound before. I have done a little snow drifting with it but that is it. Any ideas? I am 99% sure it is the rear. Also, if I grab either rear tire with both hands and try to shake the car back and forth, I get somewhat of the same noise but i really have to shake it hard so I'm not convinced the two noises are related...
    HELP?!?!?!?
  2. Nov 17, 2011 at 8:51 PM
    anormis
    anormis Well-Known Member
    Anthony
    St. Charles MO.
    BarcelonaRed 2010 D.C V6 4.0 Liter 4x4
    Hunter trucks brush guard, pcd performance chip, tailgate theft mod,blacked out badges, painted engine cover, black tail lights, modded mud flaps, painted black grill, seat belt beep mod, rear TSB!.yellow fogs red led map lights. Painted switches black, painted hood scoop, black center console and overhead console. Black wheels! Red calipers.
    mine does this when i wheel. free bump and subbed
  3. Nov 17, 2011 at 8:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Spare tire loose in the carrier ?
  4. Nov 17, 2011 at 9:05 PM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    Thats a good guess, i haven't checked, i thought about that too but i removed it from my mind as an option because i just don't think it is it but ill go wiggle it around when i can...
  5. Nov 17, 2011 at 9:40 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    My first thought as well.
    Also check your shock bolts.
  6. Nov 17, 2011 at 9:40 PM
    OZ-T
    Peter North
    British Columbia
    I had that happen in my old truck , such a dumb thing but it had me guessing for quite a while before I figured it out .
  7. Nov 18, 2011 at 8:51 AM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    Pshh...eff those shocks, they were like $10 a piece extra with my lift and they are stiff as hell. I'm pretty sure they put sand in them instead of oil...
  8. Nov 18, 2011 at 9:22 PM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
  9. Nov 19, 2011 at 1:35 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Get under your truck with a socket set and a torque wrench and check every nut and bolt you can find.
  10. Nov 19, 2011 at 9:42 AM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I'm having this problem too. I think my leaf springs wore out the pad that's in between. I can never duplicate the prob at stand still but when I hit a little bump I can hear it
  11. Nov 19, 2011 at 9:46 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    My guess is the spare tire carriage
  12. Nov 19, 2011 at 9:47 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    loose trailer hitch ball mount?
  13. Oct 9, 2012 at 7:53 PM
    XREILLYX
    XREILLYX Well-Known Member
    Reilly
    okanogan
    07 white double cab
    blacked out taillights, White OME 885X's, Billy 5100's around, added 120v/aux charger, Browning sticker!
    same thing! but i dont know if my leafs are warn out.
  14. Oct 9, 2012 at 7:57 PM
    bwood_usmc
    bwood_usmc Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    My trailer hitch makes all kinds of noise back there.... at least that is what I have believed for the last 4 years and nothing has fallen off yet....
  15. Oct 9, 2012 at 8:18 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    They may be stiff, but the nuts could be a little loose, make sure the bushings have a little compresssion on them on the top stem.
