Clunk from rear
Discussion in 'Suspension' started by Blacktaco2042, Oct 15, 2018.
  1. Oct 15, 2018 at 6:40 AM
    Blacktaco2042
    Blacktaco2042 [OP] Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    I got a 10 taco with 6112(5th notch) and5160 rear shocks and darak leafs. When going over uneven bumps I get a heavy clunk from the rear and you can feel it in the floor. When lifted off the ground the driveshaft where the slip joint is if I hit the shaft it makes a loud noise. I have a new shaft on the way from Toyota. My extended warranty covered it. Y'all think it could be anything else. I checked the front end and it's all tight.
  2. Oct 16, 2018 at 7:34 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Could be a bad shock. Had an old man emu rear shock replaced under warranty a couple of years ago.
  3. Oct 16, 2018 at 7:38 PM
    Blacktaco2042
    wisconsin
    Don't think so
