Clunk from reverse to drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by TaCoJoE650, Nov 4, 2017.
  1. Nov 4, 2017 at 1:38 PM
    TaCoJoE650
    TaCoJoE650 [OP] Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Getting a clunk when shifting from reverse to drive. Although u-joints seemed fine I replaced anyway with no difference. I'm hoping it's not excessive backlash in rear end. No carrier bearing. Can Slip yoke on tranny cause noise?seems kinda sloppy on trans outputshaft. Noise also heared when slowing down and accelerating.
    Wish the wife knew how to drive stick so I could Jack it up and listen :frusty:
  2. Nov 5, 2017 at 5:44 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    our trucks have clunky gears, especially 1st and reverse. kinda a trade mark with first gens
    wolfpackbd22 likes this.
  3. Nov 5, 2017 at 10:04 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It’s hard to know if the clunk you’re describing is bad or normal.
    Every 5 speed I’ve owned, toyota or not, “clunks” a bit when you shift fairly quickly from reverse to forward, or visa versa. You’re reversing the direction everything is spinning, so it’s going to clunk a bit unless you let the tranny slow down before shifting.
    The question I have is has it always done this, or does it seem like it’s getting worse?
  4. Nov 7, 2017 at 3:49 PM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Just purchased truck about a month ago. Definitely come from rear either diff or leaf spring
  5. Nov 7, 2017 at 3:56 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Axle wrap? 1st gens have weak leaf packs that allow the rear axle to move slightly when braking or accelerating as the drive shaft is stretched/collapsed by the motion. Nothing terribly harmful to the truck but it is annoying. I know it drove me crazy, always felt like the car behind me was nudging me.
    New leaf packs or an add a leaf may help
  6. Nov 8, 2017 at 8:28 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    More info always helps
    Auto or stick?
    5-lug or 6-lug?
    When was the last time the drive-line was lubed, assuming its lube-able?
  7. Nov 8, 2017 at 8:56 AM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    5 speed 5 lug. I just installed new serviceable u joints and lubed slope yoke.
