Clunk In Front Suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JonSVSB, Aug 9, 2016.
  1. Aug 9, 2016 at 1:43 PM
    JonSVSB
    JonSVSB [OP] Well-Known Member
    2017 Tundra TRD OR Crew Max
    Hello Everyone,
    Odd question. Whenever I first drive my truck after sitting overnight, or at work, and when I go over a speed bump at a conservative speed, not speeding or crawling, there is a loud clunk sound in the front suspension. It only happens on the first speed bump, and not the ones following, I have about 5 on my street. It's not the best sound.
    It would be on the compression portion. And before everyone tells me to slow down, I literally am going 5-10mph. These are small bumps. Also, happens on driveway exits.
    Ideas?
    2016 4x4 SR5 Stock
    Thanksin advance
  2. Aug 9, 2016 at 1:53 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Post a vid, with sound of course.
  3. Aug 9, 2016 at 2:04 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    manual or automatic? i notice my MT sounds horrid over bumps with the clutch pedal depressed.
  4. Aug 9, 2016 at 2:05 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Could be anything, if you're still under the 2yr/24k warranty have your dealer look at it.
    I don't think anyone of us can see under your truck up close and personal like they can.
    Hope that helps
    Cheers!
    Firebird likes this.
  5. Aug 9, 2016 at 2:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I get a clunk too from my aftermarket suspension over harsh speed bumps going about that speed. Mine is on the decompression though (back side of the speed bump) Someone mentioned it might be the internal bump stop of the shock. Could possibly your problem.
  6. Aug 9, 2016 at 2:17 PM
    JonSVSB
    Mine is a automatic. Ill try and video on the way home, or at least get the sound.
  7. Aug 9, 2016 at 6:48 PM
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    Same issue here and have been wondering what it could be. Only in the morning....
  8. Aug 9, 2016 at 7:39 PM
    mike1972
    mike1972 Well-Known Member
    Rochester, NY
    2016 TRD Sport DCSB Manual White
    May sound crazy but possibly the abs system.
    James_Bond likes this.
  9. Aug 11, 2016 at 10:56 AM
    JonSVSB
    All of my video attempts have been futile. Now I'm practically searching for big bumps to make the clunking sound.
    Who knows, probably should just upgrade to ICON....
  10. Aug 11, 2016 at 10:58 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Defective shocks...?
  11. Aug 11, 2016 at 11:01 AM
    mike1972
    Rochester, NY
    I have a very similar noise when going into a driveway with a bit of incline/bump at an angle. Had it with stock suspension and still today with 887 coils and 5100s.
    hueman562 likes this.
  12. Aug 11, 2016 at 11:08 AM
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    I had a similar noise and I tightened up the cab mounts just a little and the noise has stopped.
  13. Aug 11, 2016 at 11:25 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I'm a clunker at low speeds over speed bumps. But the manual transmission also chunks and clanks loudly if you shift 1st to 2nd at low speed. I figured it was just a tacoma thing.
    Which positions? All? And did you tighten from the nut side (under truck)? I'd assume you did, it would be a lot of effort to access all of the bolts in the cab.
  14. Aug 11, 2016 at 4:22 PM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Check the RF radiator support body mount. Had one that wore through the rubber. Then have the dealer replace it
