Clunk in transmission when coming to a stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redline870, Jul 9, 2019.
  1. Jul 9, 2019 at 1:52 PM
    Redline870
    Redline870 [OP] Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Wondering if anyone has experienced this issue. Every morning I remote start my truck and let it warm up for at least 5 minutes before driving. I drive about a quarter of a mile to the end of the street and begin slowing down for the stop sign. Just before coming to a complete stop, the truck downshifts hard (clunks) into first gear. It doesn’t do it every time and it’s much more noticeable if the ambient air temp is low. I still have noticed it a few times in the hotter summer weather though.
    I took the truck in to Toyota around 5k miles for an oil change and tire rotation, and asked them to look at it. They found the ATF level to be a little over a quart low from the factory (*slow clap* for Toyota, nice work guys). After filling to the correct level it got marginally better but is has definitely not been eliminated. I took it in again for the 10k mile oil change and tire rotation and again asked them to look at it. They said it was normal for a chain drive transfer case and to not worry about it. I’m convinced they’re feeding me bull shit so I wanted to find out if anyone else has, or is, experiencing this. Thanks for your time.
  2. Jul 9, 2019 at 1:55 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
  3. Jul 9, 2019 at 2:20 PM
    Redline870
  4. Jul 9, 2019 at 2:42 PM
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
    This is happening to me on my 2017 3.5L Auto. Never happened on my 2015 Manual. It's definitely from going from 2nd to 1st gear. I have zero lift, and haven't done anything mod wise to the truck.
  5. Jul 9, 2019 at 2:45 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Could be the trans axle joint?
  6. Jul 9, 2019 at 2:48 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Try it in S3 and report back.
    shakerhood likes this.
  7. Jul 9, 2019 at 2:55 PM
    TacoinMD
    TacoinMD Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    This is the story I received on at least 3 separate visits to the local dealer for oil changes and tire rotations.
    Normal condition, related to pressures in the transmission leveling out during the warm up cycle.
    My dad, brother and I (2017's 3.5L) all have the same issue during the warm up cycle.
    SandyTaco4x4 and 2016Tacoman like this.
  8. Jul 9, 2019 at 2:55 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Mine does it also. It's done it so hard I thought I got rear ended by the car behind me. Documented at dealership & no fix from Toyota at this time
    Taco_Coma likes this.
  9. Jul 9, 2019 at 3:18 PM
    Redline870
    Leave it in S3 while coming to a stop? What is supposed to happen?
  10. Jul 9, 2019 at 3:19 PM
    Redline870
    Neither do I. Makes me a little concerned for what might happen if I do decide to lift it because then it will be out of warranty!
  11. Jul 9, 2019 at 3:36 PM
    splitbolt
    NW Arkansas
    Don't put it in D at all. Start your trip down to the stop sign in S3.
    S3 eliminates all torque converter lockup.
    Braking cancels full lockup in D, but does not cancel flex lockup.
    One job of flex lock is to smooth the shifts; but if the flex lock program or parts are making the clutch grab and release when it's not supposed to...
  12. Jul 9, 2019 at 4:03 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    My dealers #1 complaint for any Toyota vehicle. It’s known and acknowledged by Toyota, but no fix. I’ve learned to brake differently to avoid it. Just like I’ve learned to not hover around 56-61mph to avoid the rear diff howl ha
    bax likes this.
  13. Jul 9, 2019 at 4:06 PM
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    I throw the truck in neutral as I approach a red light during warm up cycle. It avoids the jolt. Then when the temp needle is full operating temp It doesnt do it anymore.
  14. Jul 9, 2019 at 4:10 PM
    trazerr
    Oregon
    Unfortunately mine does it when it’s fully warmed up as well. Kind of has a mind of its own.
  15. Jul 9, 2019 at 4:13 PM
    11Bravo4x4
    Mitchell
    Did you make sure you got TSB-0062-18?
    Also make sure your tranny level is at the correct level. I just learned to live with it.
  16. Jul 9, 2019 at 4:13 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    mine does it just once in a while. like there is slack then it catches up,clunk.
  17. Jul 9, 2019 at 4:45 PM
    trazerr
    Oregon
    Yup, I have the latest TSB. It’s not for the clunk though so it didn’t change it any. Haven’t personally checked the fluid yet. But I finally got the fluid for it so that’s next.
  18. Jul 9, 2019 at 4:45 PM
    Redline870
    Haha mine does that howl too! I asked them to look at that too and they said they couldn’t reproduce the problem!
    trazerr[QUOTED] likes this.
  19. Jul 9, 2019 at 4:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Guys, this ain't a problem.
  20. Jul 9, 2019 at 4:49 PM
    Redline870
    It may not be a problem, but it’s a bit annoying that if I ride in a POS Colorado it doesn’t do it, yet my $40k Tacoma does.
    SandyTaco4x4 and MrBrooks like this.
