Clunk noise of small ledged bumps. CV's or sway bar end links?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fabulous, May 26, 2014.
  1. Jul 22, 2014 at 4:07 PM
    #41
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Here is a video of the noise!!!!
    I can also confirm that I get the click on smooth pavement when turning right.
    http://youtu.be/auBHWWVN46c
    Please help!
    For the record, I've got a Canadian Spec 2013 TRD Sport with 15,000km's on her with the OEM Baja Suspension installed.
  2. Jul 23, 2014 at 8:14 AM
    #42
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    that sounds like the click i get from my brakes when i go from reverse to drive....
  3. Jul 23, 2014 at 8:26 AM
    #43
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I have a similar issue but no money to 're do the whole suspension, I think my bushings on my shocks are shot though
  4. Jul 23, 2014 at 10:35 AM
    #44
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    2.5" lift, 285's, CB, DIY HiLift Bed Mount, AllPro Sliders,Warn
    That sound is very similar to tapping a wrench on the dust shield for the brakes, anything interfering in that region? But if you're getting that from the ball joints, tightening them won't change anything unless they are loose. If the joint is worn out, it's time to replace them period. Have you tried working the ball joints around to check for any play?
  5. Jul 23, 2014 at 6:03 PM
    #45
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Not sure what could be interferring in that region? It's basically a stock Baja truck.
  6. Jul 24, 2014 at 8:47 AM
    #46
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    You could try loading your ball joints with grease and if that dampens the noise you will know they need replacing.
  7. Jul 24, 2014 at 9:23 AM
    #47
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I thought our ball joints were sealed units? How would I load it full of grease if no zerks?
  8. Jul 24, 2014 at 10:38 AM
    #48
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    Might be mistaken, having a hard time associating the images in my head with the two jeeps I've owned and the two Toyotas. With no zerks you're back at trying to shake, or work them around with a prybar to check for play.
  9. Jul 24, 2014 at 11:32 AM
    #49
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I have a hard time believing it's the actual ball joint. It's stock and only has 9,300miles on her!
    Could it have something to do with the top plate?
    Or maybe the actual spring?
  10. Jul 27, 2014 at 8:59 PM
    #50
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    BUMP!!!!
  11. Jul 27, 2014 at 10:10 PM
    #51
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    So you tried working the ball joint to check for play or you just believe that's not it? With that few miles have you tried the dealership? Unless the spring came unseated which is near impossible with struts shouldn't be the spring. Top plate? Not seeing that on your diagram you posted. Should need to tighten your shocks either. Just for kicks have you tried rotating your tires?
  12. Nov 27, 2016 at 6:20 AM
    #52
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    Thread revival!!!!!!!!!!!! Has anyone removed the swaybar?
  13. Oct 14, 2019 at 7:47 PM
    #53
    J-KIN81
    J-KIN81 Well-Known Member
    What did this end up being? I have something similar when entering my garage at a slow speed where concrete had dip leaving a 3in bump or so. Otherwise I do not typically hear it, strange.
  14. Oct 14, 2019 at 8:23 PM
    #54
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    watching for later
  15. Oct 15, 2019 at 5:29 AM
    #55
    J-KIN81
    Oddly enough it was every once in awhile previously then I got new tires and alignment and it got worse.
  16. Oct 15, 2019 at 5:33 AM
    #56
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Not sure if this is at all relevant, but my 09 RAV-4 developed a clunk in the front end. Turned out it was a bushing on the top of the strut tower had worn and the strut was moving just enough to let it make a noise...
  17. Nov 7, 2019 at 10:17 PM
    #57
    1st_rodeo
    1st_rodeo Member
    13 SR5 4x4
    eBay TRD Pro grill Bilstein 5100s Pro Comp AAL Plastidipped emblems Raptor lined grill Lamin-X amber film fogs Hail damage Shrockworks sliders Interior LEDs JDM Astar LED fogs Hikari LED headlights Avid bed bars Michelin wipers
    Did this ever get resolved?
  18. Nov 8, 2019 at 2:52 PM
    #58
    JoshS
    Josh
  19. Nov 8, 2019 at 2:55 PM
    #59
    JRMiller
    JRMiller Well-Known Member
    James
    2017 Tacoma TRD Off Road
    I have a 2017 trd or and had a similar problem,metallic sound when hitting bumps and turning right. Seemed like it was coming from the passenger side. It ended up being the body cab mounts which were covered under warranty
  20. Nov 8, 2019 at 4:19 PM
    #60
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Bad batch of SPC upper ball joints from 2014.
