clunk noise on the passenger side after spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timbo805, Oct 13, 2009.
  1. Oct 13, 2009 at 9:57 PM
    timbo805
    timbo805 [OP] Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    hey guys i need youre help on possably finding the weird clunk noise my front end makes when i go over a pot hole or a small speed bump it comes from my passenger side and it started doing that noise since i put 2 inch spacers on my truck
    any advice is apreciated
  2. Oct 13, 2009 at 10:23 PM
    timbo805
    SanDiego
    nobody ??????
  3. Oct 13, 2009 at 10:26 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    It's probably because the shock wants to compress and the spacer is not letting it do that. Hence the clunk noise you hear. I doubt its hurting anything yet because you just installed it. Over time though, the spacers will cause your CV boots to break.
    And sorry, but it's pretty late. Most of the TW gurus are asleep. I'm sure you'll get your answer in the morning. :thumbsup:
  4. Oct 13, 2009 at 10:28 PM
    timbo805
    SanDiego
    mm i gues ile just have to wait till tomarrow then tnks for the advice though
  5. Oct 13, 2009 at 10:46 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    And also, if you don't like the stiffness of the ride with the spacers, than you should look into getting the billie 5100's from downsouth motorsports. they have a good discount on them. I'm pretty sure you'll like the ride and the look! They also won't put allot of wear and tear on your truck, and they're not much more than the spacers.
  6. Oct 13, 2009 at 10:48 PM
    timbo805
    SanDiego
    yea ive ben thinking about them
    do you think i could just put the 5100 in the front and leave the back stock
    another thing can i adjustem to 2.5 and it wont bee too stiff???
    tnks
  7. Oct 13, 2009 at 10:56 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    Yeah, you can leave the back shocks stock. At 1.75, you'll be level with the back, and at 2.5 you'll have a little rake? I'm pretty sure thats it.
    And you should be fine with them set at 2.5. Shouldn't be too stiff. Check out this guys build and you can ask him all about them.
    http://www.tacomaworld.com/forum/builds/26351-roxspin72s-build.html
  8. Oct 13, 2009 at 10:56 PM
    timbo805
    SanDiego
    tnks alot for the help
  9. Oct 13, 2009 at 10:56 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    And if you do go with these, I would think about going to the billie 5125's in the back to improve the ride in the back. That could be something you do later down the road...
  10. Oct 13, 2009 at 10:57 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    Anytime! :thumbsup:
    Pm if you have any other questions....
  11. Oct 13, 2009 at 10:59 PM
    timbo805
    SanDiego
    shure will tnks
  12. Oct 13, 2009 at 11:20 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    That noise is your truck telling you it hates you for putting spacers on it. ;)
    With that said, I would consider swapping out the spacers for a pair of 5100s up front. The ride will be drastically better than the spacers. You do not need to replace the rear shocks, although, replacing them would increase your ride quality.
  13. Oct 13, 2009 at 11:22 PM
    timbo805
    SanDiego
    yhea maibe next month you guys got my mind set to 5100 now hahaha
  14. Oct 13, 2009 at 11:25 PM
    SC4333
    Grant
    FL
    Also, If you do decided to upgrade the rear shocks too, 5100s in the rear will serve you fine unless you are going with over 2 inches of lift. The 5125 come in various length and valving that are not designed for stock height suspension.
