Clunk noise over speedbumps?
Discussion in 'Suspension' started by QuikSilver02, Aug 2, 2018.
  1. Aug 2, 2018 at 1:58 PM
    QuikSilver02
    QuikSilver02 [OP] Well-Known Member
    A.D
    02 DC 3.4L PreRunner. 1STGENN
    881 + 5100s + 10mm spacer plate 265s with TKOS Roof Rack Pioneer stereo Tailgate brake light Spyder tail lights Custom grille with toyota letters JBA UCA's Nerf Bars
    I've had this noise for 3 years since doing the spacer lift on my tacoma.
    Since I've joined, now is the perfect chance to ask for opinions.
    I have a 3inch spacer lift, stock coils, and stock Ucas. New Shocks as well. When ever i go over bumps its a loud clunk noise, just not sure what is making contact. Would new UCA's fix this? or Ditch the spacer and get a better setup ? thanks
  2. Aug 2, 2018 at 2:20 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Pictures of the setup you have right now?
    Any noticeable marks on the coil spring showing the UCA hitting? Most of the time when it comes to that kind of noise the shocks are topping out. When does it happen? on compression or rebound up?
    Welcome to the forum!!
    QuikSilver02[OP] likes this.
  3. Aug 2, 2018 at 7:51 PM
    QuikSilver02
    A.D
    for some reason i can't upload photos from my phone. But it makes a loud noise on the rebound. I think you are right with the shocks topping out. It mostly happens during a rebound going up. Going up the speed bump is okay, but when it compresses then goes back up it makes the loud noise.
  4. Aug 2, 2018 at 7:54 PM
    QuikSilver02
    A.D
    i was thinking of getting these to replace my Current Spacer i read somewhere that the spring rate is only 545lb Which is perfect.
  5. Aug 2, 2018 at 7:58 PM
    eon_blue
    Azusa, CA
    That should definitely take care of it...spacers accomplish the lifted truck look but they aren't good for your suspension or the quality of your ride, especially at 3". The kit you linked to is a solid suspension lift kit and should serve you very well.
  6. Aug 2, 2018 at 8:16 PM
    QuikSilver02
    A.D
    Thanks man, i decided against the OME881s I think this toytec lift will be great. just gotta save up, fall semester is starting back up :frusty:
    eon_blue[QUOTED] likes this.
  7. Aug 3, 2018 at 7:02 AM
    Toytec Lifts
    Rocky Mountains
    Sounds like your shocks are topping out..
    The Eibach kit you posted a link up to will be perfect for your application honestly. Great durable setup, awesome ride quality, and a solid price overall!
    Shoot me a pm if you have any questions or concerns.
    thanks
    David
