Clunk Noise Rear End of Truck When Suspension Flexing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJC84, Sep 10, 2017.
  1. Feb 14, 2018 at 8:40 AM
    jnmargarit
    jnmargarit Well-Known Member
    Vancouver, B.C.
    '14 TRD Sport
  2. Feb 14, 2018 at 10:18 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    I installed these...energy suspension. forget where i purchased them from though.
    EdgemanVA and llamasmurf like this.
  3. Feb 14, 2018 at 12:34 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Don't blame the Dakar springs just yet. I've been struggling with the exact same issue on my pretty much stock 2014 TRD Sport for months now. The worst part is that it comes and goes. Sometimes it's loud as hell while other times it's fairly low key - and then it goes away for days at a time. Although I have a set of Timbrens installed on top of the leaf packs, my suspension is otherwise stock. I've been all over the whole rear end of the truck and have checked / tightened everything including the shocks, the Timbrens, the trailer hitch mounts, the lug nuts and the spring hangars. All to no avail.
    I too was leaning towards something shifting around in the leaf springs and haven't totally ruled it out yet. I do have a tiny bit of play - depending on how level of a surface the truck is parked on - in the bed / box attachment bolts. As soon as the weather improves up here I'm probably going to be adding some rubber bushings between the box and the frame to see if that takes some of the clunking away. I hope that helps someone.
    llamasmurf and jnmargarit like this.
  4. Feb 14, 2018 at 12:39 PM
    jnmargarit
    Vancouver, B.C.
    '14 TRD Sport
    I have yet to try torqueing down the bed mount bolts. It's definitely a thought now, since the clunk definitely is coming from that area.
    llamasmurf likes this.
  5. Feb 16, 2018 at 5:13 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I changed the bushings on leaf springs where they bolt to the shackles, but I didn't change the bushings where the shackle bolts to the frame. I believe those factory bushings are pressed in.
  6. Feb 16, 2018 at 11:13 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Change those too
  7. Feb 17, 2018 at 9:40 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    So my clunk is the bumpstops. Guess I am retarded.
    When I upgraded my suspension I also put 300lbs of sand in the back for winter, to get better traction. It has worked with the traction, but it sinks the rear quite a bit and its riding pretty close to the bumpstops all the time. The Timbren Active Off-Road bumpstops are pretty tall.
  8. Mar 27, 2018 at 6:06 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I know what my clunk is. Its the Dakar leafs shifting and clunking. In wet weather it does it easily, in dry warm weather its harder for the leafs to shift. I could fix it by installing something indetween the leafs, maybe i will when i get motivation and report back.
  9. Mar 27, 2018 at 6:20 PM
    matt1381
    matt1381 Well-Known Member
    Independence, KY
    05 4x4 SR5 TRD
    OME 885 Front Coils All Pro 3 inch Leaf Springs 285 75 16 Pro Comp All-Terrains
    I have the same noise with the all pro standard leaf springs. Been searching forever and even added a budbilt traction bar thinking it was axle wrap. That didn’t fix the problem either.
  10. May 9, 2018 at 5:22 PM
    kylerocker10
    kylerocker10 Well-Known Member
    Washington
    2016 TRDOR DCSB MT QS SOLD
    BFG KO2's 265/75r16 32" OPT7 light bar mounted behind grill Softopper Canopy (black) Total Chaos UCA Fox 2.5 rr DSC Coilovers Fox 2.0 rr rear shocks w/adjuster Icon rxt leaf springs config 2 Weathertech stone/bug deflector CBI hidden winch mount Smittybilt x2o 10k synthetic winch
    I have a 3rd gen but have the same problem where my truck makes a clunk sound when turning and shifting weight, seems to be coming from the rear. I took the truck in to Toyota under warranty thinking it could be coming from where the bed mounts to the frame (already had a rattle from this area that my off road shop fixed with a rubber bushing). After over a week of troubleshooting and starting a case with Toyota corporate they called me today to tell me that they had isolated that it was coming from the leaf springs and then reverberating though the rear of the truck and bed. They said a technician was able to tightly hold they leaf pack while they shook the truck back and forth and make the sound go away. I'm going to check the isolators on the leaf spring packs when I pick up my truck tomorrow but I will be disappointed if the sound is coming from the leaf pack shifting. I already had ARB warranty my CS047R leaf pack and replace with the EL096R. Has anyone else had this specific issue with Dakars? Fix?
  11. May 9, 2018 at 5:25 PM
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    I have the same noise Goin on it sounds like mine is coming from driver side leaf pack.
  12. May 9, 2018 at 9:48 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    A while back, I had a clunking noise coming from the rear end area. It only occurred when I was backing down the twisting sloped driveway where I park everyday. It turned out to be a warped brake drum, funny, it only did it in reverse.
    jnmargarit[QUOTED] likes this.
  13. May 12, 2018 at 10:50 AM
    jnmargarit
    Vancouver, B.C.
    '14 TRD Sport
    Mine does it randomly in both forward and reverse. I haven’t looked into the brakes yet.
  14. Jan 18, 2020 at 8:21 PM
    hammertaco11
    hammertaco11 Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    Any solid update on this? My clunk is getting annoying and I'm starting to check off things on the list that dont work...tighten U bolts, tighten bed bolts, tighten shackle bushings, tighten shocks, the spare tire and I'm still clunking. My next step might be to go to some new shackle bushings, what do you guys think?
  15. Jan 19, 2020 at 6:53 AM
    #35
    Too Stroked
    Tom
    Remember, tightening the bed bolts might not do the trick. I had to shim one of them to solve my clunk. To see if this is required, go to each corner of the bed and shake it up and down. If you feel play, shimming is required.
  16. Jan 19, 2020 at 4:12 PM
    #36
    hammertaco11
    East Bay, Ca
    interesting! where would i shim? underside of the bed where it attaches to frame?
  17. Jan 19, 2020 at 6:48 PM
    #37
    Too Stroked
    Tom
    That's where I placed mine. I think I even have some of the shimming material left someplace if you need it.
  18. Jan 19, 2020 at 6:55 PM
    #38
    hammertaco11
    East Bay, Ca
    what shim material did you use? And is your clunk 100% gone?
  19. Jan 20, 2020 at 3:32 AM
    #39
    Too Stroked
    Tom
    I used a thin, white polymer (plastic) material available in sheets and cut it to size. I actually got it as a result of a post I saw here somewhere on how to fix the clunk.
  20. Aug 12, 2020 at 4:35 AM
    #40
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    hey OP did you ever find cause of your issue?
