Clunk noise tcase or transmission?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Jul 22, 2023.
  1. Jul 22, 2023 at 5:21 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    been chasing this clunk for awhile.
    Having a clunk sound identical to a bad ujiont when accelerator is 1st pushed down and a clunk noise when you let up on accelerator.
    Does it going from 1st to reverse with brakes on too and changing from gear to gear.
    If I put it in 4x4 there's no knock sound, it goes away.
    Ujionts are new.
    I can feel the clunk in the stick shift,
    is this a tcase problem or transmission problem?
    both are working perfectly otherwise.
    Had the rear end inspected by two different repair shops and both said the rear diff is fine.
  2. Jul 22, 2023 at 5:32 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    How's your carrier bearing and motor mounts?
  3. Jul 22, 2023 at 5:33 AM
    1997tacomav6
    Denver
    Single cab. No carrier bearing, mounts look fine, when you turn the drive shaft by hand you can hear the clunk and seems to be coming from tcase transmission area but noise travels to know for sure
    bkhlrTaco's[QUOTED] likes this.
  4. Jul 22, 2023 at 7:52 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Can you feel any rotating free play ?
    This in one of those feels more from experience learned overtime.
    This is with the truck in the air or on the ground?
    As things age they do wear it does not take much slop to cause a clunk.
  5. Jul 22, 2023 at 7:49 PM
    1997tacomav6
    Denver
    With it up in the air you can hear the clunk too when turning the driveshaft back and forth and sounds like it coming from the tcase but sound travels so it hard to tell.
    I don’t want to replace the tcase case and find out it’s the transmission or something else
  6. Jul 22, 2023 at 7:54 PM
    Bivouac
    Transmission in gear T-case in neutral see what it does!!
  7. Jul 22, 2023 at 7:56 PM
    1997tacomav6
    Denver
    Nothing happened because the tcase is disconnected but in reverse the transmission or tcase makes bears noises but no movement of course when the tcase is in neutral and transmission is in reverse only, when in forward gears no noise
  8. Jul 22, 2023 at 8:03 PM
    Bivouac
    I would need to look again just how much of the case still spins when in neutral .
    1997tacomav6[OP] likes this.
  9. Jul 22, 2023 at 8:05 PM
    1997tacomav6
    Denver
    Ok, it strange because reverse makes a lot of noise and the forward gears 1-5 makes zero noise
  10. Jul 22, 2023 at 8:10 PM
    1997tacomav6
    Denver
    I guess if the chain has been streached it might?
    It’s got 750,000 on that chain,
    Is there a way to test or tell?
  11. Jul 23, 2023 at 12:57 PM
    Bivouac
    Pull the case and look about the only way.
    Maybe leading with 750,000 miles on the case might have been good.:rofl::rofl::rofl:
    It has done well! Time for a complete over haul ?:amen:
  12. Jul 24, 2023 at 2:12 AM
    1997tacomav6
    Denver
    I just don’t know if it’s the tcase or transmission
