Clunk noise when braking as truck pitches forward and backward
Discussion in '1st Gen. Tacomas (1995-2004)' started by timallday, Jun 16, 2023.
  1. Jun 16, 2023 at 9:35 PM
    timallday
    timallday [OP] Active Member
    Tim
    2019 Tundra, 2004 Tacoma
    Hey peeps,
    A few months ago I wrecked my 04 single cab. Caused some damage to the driver apron, panel and hood. Took it to a shop where they replaced the body stuff and had another shop replace the driver joint and control arms. As well as the tie rods.
    Now, after I’ve been driving the truck and things loosen up, when I brake and come to a stop and as the truck pitches forward and backward as I accelerate. There’s a pretty loud clunk. I would take it back to the shop, but I had it worked on 3 hours away in my hometown as it was much more affordable than where I live.
    I called the shop and they’re super apologetic and are working with me to get it looked at. But, that all takes time and effort. Is there anything y’all can suggest I take a look at that may be a quick stand out fix? Such as tightening something’s that’s loose, etc.
    Thanks in advance!
  2. Jun 17, 2023 at 2:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What kind of mileage are we dealing with?
    First unless your real hard with the braking and acceleration your truck should not be pitching.
    Have You ever changed the coil overs or maybe just the shocks?
    No special order here just how they popped into my head.
    Engine or Tranny mounts .
    failed or missing bushings shocks /control arms I would inspect the front suspension and control arms.
    Toyota Control arms or aftermarket?
    exhaust rubber hanger failed exhaust system banging around
    loose heat shields banging around
    Good Luck.
  3. Jun 17, 2023 at 5:53 AM
    Madjik_Man
    Colorado Front Range
    Axle wrap
    Slip yoke
    Carrier Bearing
    Torque converter (auto?)
    I get that thump when coming to a stop or starting. Not every tine but a lot. These are some of the things that pop into my head as well.
  4. Jun 17, 2023 at 7:22 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    All good things to rule out listed above. I'll add a couple more that've caused the same on my truck:
    Toasted sway bar end links
    Dilapidated front differential mount bushings
    Skid plate bolt comes loose
    Bivouac likes this.
  5. Jun 19, 2023 at 5:47 AM
    Bivouac
    OP any updates on this adventure
