Clunk noise when breaking going reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Sep 29, 2023.
  1. Sep 29, 2023 at 6:38 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    Sometimes when I break while reversing specially when turning the wheel I hear a clunk or some noise. Doesn’t occur all the time maybe 20-30% of the time.
    even realized it also makes the noise when not in reverse but that happens very infrequently.
    is it normal? Or is there something wrong that I am missing. Should I take it to dealer for inspection?
  2. Sep 29, 2023 at 6:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You’re hearing the pads shift and clink into the caliper. They butt up against a shoulder on the caliper for support. Normal. You hear the noise anytime you brake in a new direction. If you’ve been driving forward and then go in reverse, you’ll hear it once. Probably will hear it the next time going forward but just depends. Also depends on the environment as to whether or not you can hear it.
  3. Sep 30, 2023 at 2:24 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Had this same problem. Pull pads, remove shims, clean back of pads/shims, and pins. Apply new coat of brake grease on backside of pads/shims and pins.
