Clunk noise when shifting 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvparadise, May 6, 2020.
  1. May 6, 2020 at 9:45 PM
    mvparadise
    mvparadise [OP] Well-Known Member
    2013 Toyota Crew cab 4x4
    When shifting from 4wd low back into 2wd the trans makes a clunk sound when I drive forward as it goes into 2wd gear. Is this a normal sound. I can feel it in the truck when it does this. Had trans serviced 100 miles ago. Anyone else have this happen? 2013 4.0 with 105k Auto trans.
  2. May 6, 2020 at 9:47 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    Are you letting it coast while you shift. Or if it's a manual transmission, putting it in neutral.
    mvparadise[OP] likes this.
  3. May 6, 2020 at 9:47 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Pretty normal, you can usually find a sweet spot in the rpm range when letting off the gas to turn the knob and it will shift in/out smoothly.
  4. May 6, 2020 at 9:49 PM
    mvparadise
    Auto trans here.
  5. May 6, 2020 at 9:55 PM
    mvparadise
    No coasting I stop put it in neutral then into 2wd then clunk when I move forward.
  6. May 6, 2020 at 10:02 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    That’s normal. As the other guy mentioned, there’s a sweet spot for a smooth transition but you can engage/disengage it while stopped or coasting. So long the wheel is straight
  7. May 6, 2020 at 10:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s normal.
    It’s also normal that the sound is louder sometimes than others.
    The Transmission Service should have nothing to do with the sound.
    The sound is in the Transfer Case that is bolted to the Transmission.
    Or possibly the A.D.D of the front axle. (Not likely since you hear the sound in the area of the Transmission)
    I think you are totally fine.
