Clunk over bumps while steering.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jazz1one, May 25, 2021.
  1. Jun 2, 2021 at 10:30 PM
    Jazz1one
    Jazz1one [OP] It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    I ended up removing the mounts for the PS lines and the AC line and got enough movement to fit the tools in there.
    The hex bit is a 24mm if anyone was wondering. Biggest I could find was a 22mm and a 7/8 which equals 22.23mm
    I wrapped some tape around the 7/8 hex to make it sit a bit tighter and that did the trick for me.
    In the end it was a waste of time.. tightening the slider bushing didn’t get rid of the clunk. I even went as far to the point where the steering would not return to center. Didn’t make a difference with the clunk. Set it back to normal.
    I’m now thinking my clunk is coming from between the rack and the intermediate shaft. The search continues...
    btw the spring is 19mm so we found that out :thumbsup:
  2. Jun 3, 2021 at 9:30 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Jazz! Thanks for the update! Did you by chance get a look/pic at the slider surface of the bushing? That style of cap is definietly different than my 2013. You actually have a recess for the spring on the cap side, mine is flat, and on the bushing side the spring has a pretty deep recess that the spring only sticks out 3mm or so.
    Sorry it didnt solve your clunk. Have you looked at inner tie rod slop?
    I found it easiest to find the cluck with someone in the truck while its off jerking the wheel back and forth pretty violently. You can safely wrap your hands around different joints to feel for slop that way.
  3. Jun 3, 2021 at 9:57 AM
    Jazz1one
    Calgary AB
    Didn’t look inside at the bushing. It’s a hard angle to even get a tool in there.
    Inner/outer tie rods are new.
    I’ll zoom in on the steering linkages when I get a chance next. I was able to get play on the u-joint at the steering shaft when I moved it back and forth with my hand. Is that normal or a that he issue?
  4. Jun 3, 2021 at 12:37 PM
    nd4spdbh
    SoCal
    You will want to wrap your hand around or get a real good look on the steering shaft u joints to view rotational play.
  5. Aug 3, 2024 at 4:22 PM
    nd4spdbh
    SoCal
    Going to bump this. @Jazz1one did you ever figure out the issue
    I have clunking issues with my steering brand new inner and outer tie rods, it's either an intermediate shafts u joint (which both of them feel SOLID with no slop) or the rack gears themselves.
  6. Aug 3, 2024 at 4:35 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    reading i have a similar issue
  7. Oct 1, 2024 at 12:13 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I have issues with clunking that I cannot locate, yet. I've narrowed it down to my steering. Like you, I replaced my inner/outer tie rods, and I just replaced my intermediate shaft. No luck. I'm going to try your slider bushing adjustment on the rack and see if that helps.
    I've taken this to my trusted mechanic, but he can't find anything wrong (which is good I guess).
  8. Oct 1, 2024 at 1:15 PM
    nd4spdbh
    SoCal
    Please come back if you ever find this. I have adjusted my slider bushing and the steering is smooth and tight (cant go any tigher with the bushing otherwise it doesnt self center due to too much drag) but still have the clunking.... so its looking more n more like steering rack gears.
