"clunk/pop" when turning!
Discussion in 'Technical Chat' started by dustinclm, Nov 29, 2010.
  1. Nov 29, 2010 at 9:12 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    i have noticed lately that when backing out of a parking spot and turning the wheel clockwise there is a loud popping noise that frequently happens. sounds like it is coming from the drivers side suspension. occasionally i notice it when the front left tire goes over the curb when pulling into the driveway. what could be causing this? it has happened in the past nad i havent worried about it but now it is more frequent. i have a '01 prerunner with a 3' lift and 32" tires, any ideas?
  2. Dec 6, 2010 at 7:27 AM
    ThisGuy
    ThisGuy Well-Known Member
    Brad
    litchfield park, az
    All Black 2010 4x4 DC TRD Sport
    3" lift, PC wheels, 33" Cooper SST. Volant intake w/ scoop, Gibson exhaust, black tails & 3rd, grillcraft black mesh....more to come
    Im surprised to see there are no responses to this. I have the same problem with my 2010 DC 4x4. Any help would be appreciated.
  3. Dec 6, 2010 at 7:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Mud flaps or Pinch weld mod or bad ball joint.
  4. Dec 6, 2010 at 11:00 AM
    dustinclm
    Thibodaux, La
    my mub flaps have been off for year, my only guess is that it could be something like the ball joint or the control arms but im not sure....it hasnt really madethe noise since i posted this, it comes and goes, so i have no ideawhat it could be
  5. Dec 6, 2010 at 11:02 AM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    with out a doubt its your ball joints, that happened to me with my old s10. It was a mix of my bad steering box and the ball joints. Get that isht fixed. My wheel ended up falling off on me.
  6. Dec 6, 2010 at 12:06 PM
    dustinclm
    Thibodaux, La
    is it a at home fix or should i get someone to replace the ball joints?
  7. Dec 6, 2010 at 12:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    Lower ball joint
    Upper Ball Joint
  8. Dec 6, 2010 at 12:21 PM
    milam89
    milam89 Well-Known Member
    houston,tx
    2006 blacked tacoma
    could be ball joints, but mytruck was making the same noise and it actually turned out to be busted sway bar ends (the ones that ci=onnect the sway bar to the spindle
  9. Dec 6, 2010 at 12:22 PM
    dustinclm
    Thibodaux, La
    im not able to checnk now so ill just ask, does the 2001 prerunners 2wd have a zerk to ass grease? or is it just a totale replacement that needs it?
    do the upper and lower needs to be replaced or is it just one of the two?
  10. Dec 6, 2010 at 12:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    "ass grease" :rofl:
    No, it's just a replacement. It's really up to you as far as replacing them goes.
  11. Dec 6, 2010 at 12:39 PM
    stephejm
    stephejm Member
    justin
    chesapeake, va
    i would say that if its not your sway bar or your ball joints, it could possibly be your cv starting to wear out.
  12. Dec 6, 2010 at 12:47 PM
    graymaurer
    graymaurer Well-Known Member
    Santa Rosa
    02 Tacoma TRD V6
    ^^ This applies to 4wd only. In this case, he's got a prerunner. Good idea though.
  13. Dec 6, 2010 at 12:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    *cough........cough........pre-runner.....cough cough*
  14. Dec 6, 2010 at 6:28 PM
    dustinclm
    Thibodaux, La
    well since it comes and goes and i dont tear it up on the farm anymore i guess ill try and ride it out since i will most likely getting a new truck within a year. if not then ill look into replacing this. thanks guys
