Clunk problem when driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynlan1819, Mar 25, 2017.
  1. Mar 25, 2017 at 6:57 PM
    lynlan1819
    lynlan1819 [OP] Well-Known Member
    Tacoma
    Lifted
    Hi guys,When I am driving down the road at speed on the freeway mostly and I let off the gas my truck has a clunk that I can feel as it downshifts,and if I speed back up it makes another clunk as the truck speeds up,It feels almost like the transmission maybe is not shifting right or if maybe the transmission pump ( if it has one) is not keeping up the pressure,maybe the torque converter .My drive shaft is brand new so that's not the problem.Any ideas
    2006 DBLC,V-6,auto with 116,000 on the truck
  2. Mar 26, 2017 at 7:04 PM
    lynlan1819
    Tacoma
    Lifted
    So nobody here has any ideas ?
  3. Mar 26, 2017 at 7:12 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Axle wrap maybe?
  4. Mar 26, 2017 at 7:50 PM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    My 6spd does this when you abruptly take off the gas and then go back on to the gas. I think it is normal, just a bit of play in the drive shaft.
  5. Mar 26, 2017 at 8:02 PM
    lynlan1819
    Tacoma
    Lifted
    What is axle wrap ?
  6. Mar 26, 2017 at 8:05 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    It's the factory leafs being to weak and twisting when braking hard and accelerating quick from a dead stop. basically the leaf springs going from a "U" shape to a "S" shape.
  7. Mar 26, 2017 at 8:11 PM
    lynlan1819
    Tacoma
    Lifted
    That's not the problem then,I have brand new OME 5 leaf packs on the truck.
  8. Mar 26, 2017 at 8:16 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Yeah definitely not the problem then.. You said you have a new drive shaft in the truck?
  9. Mar 26, 2017 at 8:20 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Grab the driveshaft and twist it back and forth to see if the pinion has a lot of slop in the rear axle.
  10. Mar 26, 2017 at 8:59 PM
    lynlan1819
    Tacoma
    Lifted
    Whats considered a lot a half inch/inch ?
  11. Mar 27, 2017 at 8:53 AM
    lynlan1819
    Tacoma
    Lifted
    Yeap brand new shaft.
  12. Mar 27, 2017 at 9:38 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    I'd say a lot of play in the rear end would be more than a 1/2"
  13. Mar 27, 2017 at 9:38 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    New carrier bearing with the drive shaft?
  14. Mar 27, 2017 at 10:54 AM
    lynlan1819
    Tacoma
    Lifted
    Yes complete rebuild with all new Spicer parts,and balance.
  15. Mar 27, 2017 at 10:56 AM
    lynlan1819
    Tacoma
    Lifted
    Thanks tacoma 2K4,I will look today and see how much play if any the pinion has,I know the drive shaft itself is nice and tight.
  16. Mar 27, 2017 at 11:10 AM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Hopefully you can get it figured out. I seriously doubt that there's something wrong in the transmission, I would be leaning on the rear diff slop of the pinion
  17. Mar 27, 2017 at 11:20 AM
    lynlan1819
    Tacoma
    Lifted
    Thanks brother,You are right,I checked it with the truck in neutral and there is way too much slop in the pinion gear.
    Pretty sure that's my problem,I have a warrenty for the truck,so its going in too get fixed.
  18. Mar 27, 2017 at 5:08 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    One more thing you might want to check also is the rear transmission mount, just see if you have any movement on the transmission by pushing up on it with some force. Slight movement is ok roughly 1/4"
  19. Mar 27, 2017 at 9:25 PM
    lynlan1819
    Tacoma
    Lifted
    Checked it nice and solid.....
