Clunk sound at a stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mueller, Jul 29, 2020.
  1. Jul 29, 2020 at 11:01 AM
    mueller
    mueller [OP] Member
    joe
    riverside, ca
    blue 08 4dr prerunner sr5
    I have a clunk sound in the rear end at a complete stop, foot on the break and in drive.
    Like a sensor or somthing is telling the trans to do something at this time. Again, foot on the break and for no reason a clunk sound. Any ideas?
    Its a 2008. Came with a factory biult in posi rear end.
  2. Jul 29, 2020 at 11:59 AM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    Is it a moment after you stop? Could be the spare tire moving around a little.
  3. Jul 29, 2020 at 12:19 PM
    mueller
    mueller [OP] Member
    joe
    riverside, ca
    No. It always happens..say 5 to 15 seconds after i stop. Just waiting for traffic or the light to change. Alomost like it changed a gear or something but it feels like from the rear end....
  4. Jul 29, 2020 at 12:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it do this with the AC off?
  5. Jul 29, 2020 at 12:26 PM
    itr1275
    itr1275 Well-Known Member
    Jerold
    San Jose CA
    '00 Tacoma TRD Off Road
    Icon Coilovers, Daystar Shackles. Sliders.
    U-Joint?
  6. Jul 29, 2020 at 12:40 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Splines on the drive shaft. I lubed mine and the clunk went away.
    I drive a regular cab, 4 cyl, auto, 4WD (one piece driveshaft).
    ABNFDC likes this.
  7. Jul 29, 2020 at 1:45 PM
    mueller
    mueller [OP] Member
    joe
    riverside, ca
    AC on or off same thing.
    U joints have minimal play...thier good.
    I haven't tried lubing the splines. Ill do that and see if it helps. Thanks guys for yur thoughts on this
  8. Jul 31, 2020 at 3:48 PM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    My locker dose that some times if I roll back just an inch or two
  9. Jul 31, 2020 at 3:57 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Turn up the radio!
    Not sure if this will work?
  10. Jul 31, 2020 at 3:58 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Normal..... it’s the hamsters that provide the truck with power bumping into each other at a stop.
    .....or could be axle wrap
  11. Jul 31, 2020 at 4:01 PM
    Gen2Tacoma
    North East Atlanta
    ^^This^^
  12. Jul 31, 2020 at 4:11 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Mine would thud after a stop. I lubed the splines and it went away. Later on I added a grease fitting to it.
  13. Jul 31, 2020 at 5:06 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Mine too, about 1 second after stopping, when the truck would come to a rest.
    ABNFDC[QUOTED] likes this.
  14. Aug 1, 2020 at 7:31 AM
    tonyl13
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Yep I got it wrong has to be the hamsters
  15. Aug 1, 2020 at 7:41 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This.
  16. Aug 1, 2020 at 8:35 AM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Mine was doing this. Check the forum for transmission flush. I had mine flushed by Toyota of Pensacola and it not only stopped the delayed clunk from the shift, it started shifting smooth like a brand new truck.
