Clunk sound when letting off brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kev6216, Nov 6, 2015.
  1. Nov 6, 2015 at 8:16 PM
    kev6216
    kev6216 [OP] Well-Known Member
    Kevin
    Pittsburgh
    2013 Baja
    I have a 2013 Baja. Last month I started hearing a clunk or click sound when letting off my brake when coming to a complete stop, sounds like it's coming from the passenger side rear axle. Sometimes it started before I came to the stop, sometimes after I let off the brake and hit the gas. It's driving me nuts. I greased all 4 zerks of the drive shaft that I found. I pulled both rear wheels and took apart the drum brakes. Sprayed them down with brake cleaner and put a little bit of grease on the different springs. Now, the clunk or pop is worse. Sometimes when I come to a stop sign it will do it 2-4 times. Funny how I made it worse???? wtf
  2. Nov 6, 2015 at 8:23 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You need to grease the rear brake shoes.........
    j/k;)
    What you describe is almost 100% axle wrap & axle wrap for tacomas is due to weak leafsprings
  3. Nov 6, 2015 at 8:51 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Axle wrap my friend...
  4. Nov 6, 2015 at 9:01 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Tighten your ubolts......I had the same thing, I tightened them with an impact and it went away and has not come back.
  5. Nov 7, 2015 at 6:07 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I get a clunk the first time i hit the brakes when I change between F and R. Read on here the pads are a floating design, and its normal.
  6. Nov 7, 2015 at 6:01 PM
    kev6216
    Kevin
    Pittsburgh
    2013 Baja
    Thank you JuanitoBunito! I pulled off the back tires and found that I could tighten the ubolts a little bit. I used a deep impact socket and a breaker bar and pulled as hard as I could....One of them was able to tighten about 3/4 of a turn and I think that did it!!! I drove it around all afternoon and the click/popping sound is gone!! Is that axle wrap or just a loose Ubolt? Thinking that maybe when I put my jack under my leafs to rotate my tires that it might loosen the Ubolts a little and that's what caused it??
  7. Nov 7, 2015 at 6:51 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I'm glad you got to the bottom of it!!!! Yeah it's hard to say. I've heard....and there is threads on here that the ubolts come fairly loose from the factory.....as in not as tight as they should be. Another bit of advice.....unless you have a buddy that has pneumatic tools with an impact, go to a shop and ask them to throw thier tools at it to tighten them up a bit more. I say this only because even though you were able to tighten them a little, an impact will get them really snug. :thumbsup: Good luck bro!!
  8. Nov 7, 2015 at 7:05 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Toyota specs say 37 ft/lbs for u-bolt nuts. Some speculate it's a typo and should be 73 ft/lbs. Who knows, but it's too low.
  9. Nov 7, 2015 at 7:08 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah ....there is no way in hell its 37. In a thread I saw, a Toyota tech who's a member said its a typo and it is indeed 73. He also said he feels that was too low and 90 is more of a sufficient torque spec.
  10. Nov 7, 2015 at 7:11 PM
    samiam
    Sam
    Stinky Vegas
    I talked to a custom spring builder here in Vegas a couple years ago and he said it should be 90 as well.
  11. Nov 7, 2015 at 7:15 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I bet that is probably a standard spec that all suspension guys go by.
    samiam likes this.
