Clunk sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gamehendge76, Mar 21, 2017.
  1. Mar 21, 2017 at 5:43 PM
    Gamehendge76
    Gamehendge76 [OP] Member
    Tom
    07 Tacoma Prerunner Dbl cab
    I own a 2007 prerunner with 147000 mi. It comes and goes but I've been hearing a single clunk sound when accelerating from a complete stop and when coming to a complete stop. It's usually right at that last little lurch forward when stopping and the initial lurch back when accelerating. It's seems as though something is shifting and I can feel it in my floor. I may have narrowed it down to when it's wet driving conditions and after washing the truck but I'm not confident about this just yet. I've looked around the forum and have seen similar problems but nothing that sounds exactly like what I'm experiencing. Any input would greatly be appreciated. Thanks!
  2. Mar 21, 2017 at 5:50 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    check you right front corner of your bed. the bolt hole become worn and sloppy. have you checked your u joints?
  3. Mar 21, 2017 at 6:24 PM
    Gamehendge76
    Tom
    Thanks, I will take a look at both of these. I haven't yet really looked at much of anything. I have a pretty crazy work schedule. It started I'd say about a month ago and I shrugged it off but has been very noticeable the past few days. Will report back asap.
  4. Mar 22, 2017 at 8:54 AM
    baboon
    baboon Active Member
    Get a flashlight, crawl under your truck, and take a really good look at your leaf springs.
    In particular, the spot on them to look at is immediately adjacent to the U-bolts that clamp them together with the axle tube.
    What you are looking for, is broken leaves.
    Mine did *exactly* what you describe when one of my leaves broke.
    Yours is an 07, so unless you've already had it done, it should be covered by a recall.
    If you've already had the recall done, then you're on your own.
    There is also a possibility that you have had a service bulletin applied, which would "upgrade" the springs. This is not the same as the recall -- which still applies.
  5. Mar 25, 2017 at 7:13 AM
    Gamehendge76
    Tom
    Sorry fellas, been working a slew of 16 hr days. Gonna take a look at these things when I wake up, just got off graveyard shift. Thanks for the replies, I appreciate the input. I think it's coming from the front end at this point however. Be back later....
  6. Mar 25, 2017 at 7:16 AM
    Gamehendge76
    Tom
    Oh yes and I've had the leaf springs upgraded about a year ago due to the recall notice I received.
