Clunk sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sherlock18, May 28, 2020.
  1. May 28, 2020 at 9:09 PM
    Sherlock18
    Sherlock18 [OP] Well-Known Member
    2008 Access Cab 4x4 OR
    I have an 08 trd off road 4wd access cab that I love. But for atleast the past 20k it has made a clunk noise when ever I back out of my drive or come to a fast stop. The clunk only seems to happen once per change in direction. I've had it to several shops who all keep telling me that they don't know what it is, but its safe... any help? Edit: the sound seems to be coming from the front of the truck.
  2. May 28, 2020 at 9:15 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Can you get someone to drive it back and forth while you stand nearby? Even with the hood up? Safely?
  3. May 28, 2020 at 9:19 PM
    Sherlock18
    I've tried driving it back and forth while a friend listened. He said it sounds like its coming from. The control arms.. although the shops have all said they are ok..
  4. May 28, 2020 at 9:19 PM
    Sherlock18
    the truck did have the frame replaced about two years ago for what it's worth.
  5. May 28, 2020 at 9:26 PM
    Austinguy
    Austinguy #FreeManer
    Robert
    Texas
    First on race day!
    Secrets
    Is it coming from the brakes? I know the pads can do something that sounds like what you’re describing.
  6. May 28, 2020 at 10:03 PM
    Sherlock18
    I dont think so, I've heard brakes click before, this is much louder.
    Austinguy[QUOTED] likes this.
  7. May 28, 2020 at 10:23 PM
    Austinguy
    Robert
    Texas
    First on race day!
    Secrets
    @Texoma any ideas on this?
  8. May 29, 2020 at 2:50 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Mine does this if I am backing from the driveway and have the steering wheel at full lock. Never knew what it us but it’s never gotten worse or caused an issue. I just don’t go to turn to lock now.
    BillsSR5 and Bodyguard89 like this.
  9. May 29, 2020 at 3:35 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Torque the front LCA alignment cam bolts/nuts to 130ft#'s. This is common for those to be under torqed and they'll make noise.
  10. May 29, 2020 at 3:42 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    Check your brake calipers, make sure they aren’t loose or missing a bolt, check skid plates if you have them, I have had clunks from both of these things
  11. May 29, 2020 at 4:11 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Look to see how much play there is with the carrier bearing and transmission mounts. These are causes of cluck sounds. It is true that the drum brakes do clunk when changing direction. This is normal.
  12. May 29, 2020 at 5:31 AM
    Sherlock18
    Nothing is missing on my brakes, and I'm sure its not them. I'll check the LCA bolts when I get a chance.
    Austinguy likes this.
  13. May 29, 2020 at 6:14 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Pretty sure thats the issue. That is unless of course you have SPC/LR UCAs, they have had issues.
  14. May 29, 2020 at 11:39 AM
    Sherlock18
    Might be a dumb question but tightening those bolts shouldn't mess with my alignment right?
  15. May 29, 2020 at 12:41 PM
    Sherlock18
    So I torqued the rear bolts to 100ft lbs and no clunk. This website is awesome. Also I wonder why Toyota had them so loose to begin with?
  16. May 29, 2020 at 12:44 PM
    Austinguy
    Robert
    Texas
    First on race day!
    Secrets
    @Texoma is the go to for stuff like this. He has been a great help and resource to many. +1 for Chris!!:fistbump:
    bishtaco likes this.
  17. May 29, 2020 at 2:27 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    130 is optimum
  18. May 29, 2020 at 6:37 PM
    Sherlock18
    Ok, I found a spec sheet that said 100, I was afraid of breaking a bolt
  19. May 30, 2020 at 11:18 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Trust me, it won't break.
  20. May 30, 2020 at 3:47 PM
    Austinguy
    Robert
    Texas
    First on race day!
    Secrets
    Don’t doubt the yota master :smack:
    Texoma[QUOTED] likes this.
