Clunk Thread - in higher gears with MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Oct 5, 2017.
  1. Oct 5, 2017 at 8:49 AM
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Hey, Folks.
    I searched and read threads about driveline clunks that happen under braking, 2nd to 1st shifts in autos, and some about axle wrap.
    I'm feeling a clunk in 5th or 6th gear when going on and off of light throttle. I don't know if this is just a truck thing or if it is a problem.
    If I missed a thread about this, can you please point me in the right direction. Thanks!
  2. Oct 5, 2017 at 8:52 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I believe it is just slop in the driveline, felt the same as you're describing on my truck too.
  3. Oct 5, 2017 at 9:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There will always be a clunk when going on and off light throttle in a manual. I have it in my 2017, my 1984 had it, my 1978 Chevy had it, my 1995 Dodge Dakota had it. It is inherent because of driveline design. No big deal. In a manual, you have no torque converter like you have in an automatic. You either have torque by applying the throttle or you don't. There is no middle. In an automatic, you let off the throttle there is a gradual (meaning less than a second, but still not instant) decrease.
  4. Oct 5, 2017 at 9:33 AM
    tonered
    tony
    Lynnwood, WA
    Our only other manuals were FWD, so there wasn't as many connections between the engine and wheels.
    I'm fine with it as along as it is normal and a truck thing. Just checking. I run my bike chains on the loose side of the slack spec and can usually stop the clank with smooth throttle. Still working on it with the new Taco, I suppose.
    I drove a Silverado with 120k for a friend a couple months ago. That thing was clanking all over the place and was very much worse than this. I would have guessed it was time for new joints in that. It was well cared for (ie clean), but mechanically, it was dead compared to the 2007 Taco that I test drove with 141k on it.
    Thanks for the help.
  5. Oct 5, 2017 at 9:37 AM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    Im going to check the grease my ujoints. It doesnt happen every time. I had the same issue in my 2013 6mt and had to add grease. That solved the random clunk in that so i should help in the 2017.
  6. Oct 5, 2017 at 10:55 AM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    The 17's have sealed u joints.
    The clunking is normal.
    tonered[OP] likes this.
  7. Oct 5, 2017 at 11:17 AM
    BlueHeli
    AZ
    None
    Thats just dumb. I had to actually walk out and check. I guess i will be replaving them with greasable ones. The clunk shouldn't be considered normal by any means.
    fdbyrne likes this.
  8. Oct 5, 2017 at 12:11 PM
    aero90
    It's not that bad, sealed are structurally stronger than greasable and it really isn't hard to pull a driveshaft and replace u joints way down the line when they need it.
  9. Oct 5, 2017 at 12:12 PM
    BlueHeli
    AZ
    None
    Yeah i know. From what i have heard they dont come with enough grease in them though. Im glad there only 20 bucks to replace.
  10. Oct 5, 2017 at 12:21 PM
    su.b.rat
    su.b.rat broken truck
    i don't have a clunk and never have had it. what you guys are describing, like on the highway off & on the throttle, feels to me like a subtle snap. feels like a good engagement on a driveline with no slop. the snap is light and very tight feeling, but i still come on the throttle nice and easy to minimize it although there's nothing suggesting an issue.
    shakerhood and BlueHeli like this.
  11. Oct 5, 2017 at 12:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Um, it is. Every single MT truck I have ever driven does it, and I have drove many trucks. Also, your sealed U joint is much better than when you forget to grease yours lol.
  12. Oct 5, 2017 at 12:42 PM
    BlueHeli
    AZ
    None
    Well my ram 1500 with a 5 speed never had the clunk . My send gen did but it was gone after i greased it. Now my old silverado did it but i chucked that one up to it being a 78. I always make sure to service them every oil change as well.
  13. Oct 5, 2017 at 12:42 PM
    eon_blue
    Azusa, CA
    My 04 does it and it drives me nuts, but it is what it is. For me it's most noticeable in the torquey lower gears (1-2, 2-3). When I grease the u-joints it calms down noticeably. Not sure if the newer Tacos have greaseable U-joints, but if they do...grease them up every 3-5k
  14. Oct 5, 2017 at 12:43 PM
    BlueHeli
    AZ
    None
    The second gen manuals had greaseable joints. This 3rd gen doesnt.
  15. Oct 5, 2017 at 12:50 PM
    eon_blue
    Azusa, CA
    Well that's lame, thought I read somewhere that the manuals did or at least had a few on one end of the driveshaft or the other. Wonder how they're supposed to hold up over time.
  16. Oct 5, 2017 at 1:27 PM
    venezian
    Los Angeles
    2022 7545E
    :facepalm:It's not "dumb" it's normal... when two metal pieces touch they will make a sound. The clunk is more pronounced if your shift is lousy.. Sometimes i'll shift too early or sometimes it's just right, but i let off the clutch too fast and there's a light clunk. my 86 HJ 5MT clunks and so does my 17 6MT Taco as well as my neighbors 12' 4cyl 5MT..
    hiPSI likes this.
  17. Oct 5, 2017 at 1:40 PM
    BlueHeli
    AZ
    None
    And its not "normal" either.
  18. Oct 5, 2017 at 1:46 PM
    tonered
    tony
    Lynnwood, WA
    I will get a small clunk when going into 5th or 6th sometimes, but I was mainly asking about going on and off the gas while already in gear.
    First truck. Just checking if it is a problem or a normal thing.
    BlueHeli likes this.
  19. Oct 5, 2017 at 4:57 PM
    tonered
    tony
    Lynnwood, WA
    Well dang. The leaves have settled a bit. I had to put a few turns on the U-bolts to get them to 70ft-lbs.
    I haven't tested it yet and am not expecting this to end the clunk. But, you never know.
  20. Oct 5, 2017 at 5:08 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Not all the u joints are covered. I was able to grease 3 of mine, IIRC.
    shakerhood likes this.
