Clunk up front: FIXED -Check Skids!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SVigg236, Feb 26, 2023.
  1. Feb 27, 2023 at 1:48 PM
    #41
    cosmic65charlie
    cosmic65charlie Consumer of good times.
    Colorado
    2019 TRD OR AC
    Offroad stuff, Audio stuff, Cooler full of beer
    Yeah, I had the same issue as well with my RCI skids. Didn't occur with just the front skid plate, but after I had added the other two, it started up shortly after. Pretty sure I over torqued them. You could actually see where the powder coat had worn away where they were rubbing each other. When I was at RCI, they had actually mentioned using rubber washers if needed to eliminate. That and a combination of properly torquing them down solved it for the most part.
    SVigg236[OP] likes this.
  2. Feb 27, 2023 at 2:21 PM
    #42
    DougNuts
    DougNuts Well-Known Member
    Georgetown, KY
    N/A
    Glad you solved it, love the looks of your truck. :muscleflexing:
  3. Feb 27, 2023 at 3:12 PM
    #43
    SVigg236
    SVigg236 [OP] Well-Known Member
    Stephen
    SE Coastal Georgia
    2022 Silver TRD Offroad 4x4
    Front and Rear bumpers, 5100’s, OME 887, and Icon lift.
    I don’t know how to change the title lol!
    Idk why these forums use the least user-friendly setup possible.
  4. Feb 27, 2023 at 4:36 PM
    #44
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    Its actually pretty easy. Go to the top of your first post on this thread. Above the black bar across the top of your first post (on the right hand side) are the words "Thread Tools". Click on it and it gives you the option of changing the Thread title.
  5. Feb 27, 2023 at 5:15 PM
    #45
    SVigg236
    Stephen
    SE Coastal Georgia
    Done. Thank you.
    Waynebarkr[QUOTED] likes this.
  6. Apr 24, 2023 at 3:10 PM
    #46
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    I just had this issue fixed with the LoStar TRD Pro Skid plate knockoff. I installed it a year ago and it started clunking 6-months ago. Brought it to my mechanic after not being able to figure out the source of the noise and he figured out it was rubbing against the front, center jack point. We added a couple of washers as spacers to create some separation. No more noise.
    But I am lost on this next part. That front jack point is advertised as still being usable even with the TRD Pro Skid plate. Maybe it is a flaw with my knockoff, but I don't see how it can be used as a jack point. Wouldn't it bend the aluminum up and into that jack point underneath and everyone would have the rubbing/clunk issue?
    denimdan73 and Junkhead like this.
  7. Apr 24, 2023 at 3:24 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I also had a clunking noise after wheeling my truck in the snow. I thought something was bent/loose because the terrain was very rough at times.
    Took off my skidplate, drove around and noises were gone. I noticed I bent the corner of the plate a bit so it wasn’t sitting “right”. Bent it back in shape, reinstalled and it’s good to go!
  8. Apr 25, 2023 at 5:45 AM
    #48
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I chased a noise like this on the FJ for about nine months. Finally decided to remove the skids…..noise went away
    BattleKat and Junkhead like this.
  9. Apr 25, 2023 at 5:58 AM
    #49
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    I’ve been hearing this same clunk on the drivers side for the last year. Only stock black skid up front no trans skid, stock suspension, I’ve had my sway bar removed completely and it still made the sound, I’ve had my skid plate off several times for oil changes and cleaning (had a wet winter :mudding:) even pulled the front struts out, installed spacers, reinstalled, then removed them again. I’ve torqued everything down to spec every time. After all that I still get a clunk from time to time…not consistently…but occasionally as I leave the driveway, hit speed bumps, roll through gutters in intersections…I just chocked it up to a 3rd gen nuance…any thoughts?
  10. Apr 25, 2023 at 6:01 AM
    #50
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    @vivid02
    Thanks!
    I figured that's what it was.
    The noise had gotten louder but was more of a suspension sound when entering my driveway or turning the steering wheel/moving forward in a parking lot. Very annoying! lol
    vivid02[QUOTED] likes this.
  11. Apr 25, 2023 at 6:08 AM
    #51
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    @MulletTaco
    A member here (Eric) identified this and posted a video with a generic fix. I'm not saying it will fix your situation but he did get positive results.
    vivid02 and MulletTaco[QUOTED] like this.
  12. May 7, 2023 at 11:54 AM
    #52
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Verified last week Tuesday at my Final ToyotaCare Service.
    The bolts connecting the TRD SKID and Talon CAT plate were causing the metal rubbing noise.
    I'm also considering putting fiber washer in between both spacers after I re-torque all the bolts.
  13. May 7, 2023 at 12:39 PM
    #53
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    As mentioned in my previous posts about the trd skid plate causing noises for some, I was finally about to play around with it. I took mine off and drove back and forth in my drive way and backing out on full lock and the noise is gone. So I reinstalled it and put 1 fender washers as a spacer and see if that helps. I reverse out of my driveway and the noise has decreased. I have the trd skidplate with rci trans skid. Also made sure everything was torqued.
  14. Nov 2, 2023 at 8:06 PM
    #54
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I have new strut to lower control arm bolts waiting to get installed but this thread is giving me some ideas on chasing my front end clunks and pops. I've got the factory TRD skid and Talons Garage cat shield. I'll report back when I have a chance crawl down there.
  15. Nov 3, 2023 at 11:25 AM
    #55
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    @SVigg236 thanks for this post!
    Needed to remove the cat shield to get the transmission fluid but figured I'd drive it to see if that was the source of my clunk and it was! Now I need to figure out how to prevent it from making noise after putting it back. Prior to removing it, I checked all the bolts and none were loose.
    Link the my post and video of the clunk mine was doing,
    https://www.tacomaworld.com/threads...-front…going-down.800581/page-7#post-28975665
  16. Nov 3, 2023 at 12:20 PM
    #56
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Our FJ did this……noise went away when skids were removed
  17. Nov 6, 2023 at 8:56 AM
    #57
    BattleKat
    San Diego
    The source of my noise was the jack point in the middle of the front end was literally in contact with the TRD Skid plate. The skid plate had rub marks all over it. Added spacers to the front mounting points to give it a small amount of clearance. I still get an occasionally clunk which I assume is the skid plate shifting slightly on mounting points.
    Jesse H[QUOTED] likes this.
  18. Dec 2, 2023 at 8:13 PM
    #58
    Diesel156
    Diesel156 Well-Known Member
    My truck started doing this last year(2 yr old truck with 12000 mi). Slow speed usually I’m going up or down from driveways. Sometimes coming to a stop too. So annoying. I will definitely check the skids. Anyone got the torque specs on the RCI skids?
  19. Dec 3, 2023 at 4:24 AM
    #59
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  20. Apr 18, 2024 at 7:29 PM
    #60
    Diesel156
    My clunk was due to my RCI full skids. I took it off and it was gone. Hope that helps
