'Clunk' when coming to complete stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulwal, Sep 13, 2017.
  1. Sep 13, 2017 at 12:25 AM
    paulwal
    paulwal [OP] Well-Known Member
    I just recently bought my first Tacoma, an '03 4x4 V6 TRD. It's making a fairly loud clunk when coming a complete stop. It happens at the moment it comes to a complete stop. It doesn't happen every time, and it may be happening in other situations as well, like accelerating. I think it's coming from the rear, but I'm not positive.
    What could it be?
    - loose U-bolts?
    - axle wrap?
    - transmission mount?
    - driveshaft?
    What is the best way to troubleshoot this?
    Fossilguy14 likes this.
  2. Sep 13, 2017 at 1:17 AM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    It's your carrier bearing... it's probably worn to shit causing slop and okay in your driveshaft ( went through the same thing you are describing) all was because my carrier bearing was due to be replaced :) I would check it out just slide under your car and push up on your driveshaft that connects to your rear axle. If there's any significant play it's probably time to replace. There is a specific number of play allowable but I forget what it is
  3. Sep 13, 2017 at 1:30 AM
    paulwal
    Ok, great. I'll check that. That doesn't sound too bad. By the way, I just went for a drive to verify my description (I haven't had the truck too long). The clunk isn't "loud". It's not really audible at all. I can feel the clunk though.
    It happens when coming to a stop, not every time, and only after getting up to speed. For example if I stop, then creep forward 5 feet and stop again, then no clunk.
    It's also doing this thing where if I accelerate to 30mph, then coast down to 20, then go to accelerate again, it feels like something takes a split second to 'catch', like there's play in something. It makes me hesitant to accelerate after coasting, so I really only do so gingerly.
    Also the transfer case is freshly rebuilt, in case that matters. Does this all jive with the carrier bearing diagnosis?
    Thank you
    Edit- I found an excellent how-to video on changing the carrier bearing and transmission mount. They both look like fairly easy jobs. I'm going to check the play in both of these tomorrow.
    https://www.youtube.com/watch?v=Ghyoacp7E1E
    philipwicker and skeezix like this.
  4. Sep 13, 2017 at 6:17 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you get a cheap go pro knock off, you can mount it under the truck and make the sound a few times and see if it looks / sounds like it's your problem. The carrier bearing bushing will usually get play in it and that allows the ds to move around. Does yours have play in it? It's always a good idea to confirm 100% what your problem is before making any purchases even if it's just for safety's sake of not driving around with a mystery sound. Not saying it isn't the carrier bearing, but it's good to have a complete diagnosis when fixing stuff if possible.
    Currygoat and otis24 like this.
  5. Sep 23, 2017 at 7:30 PM
    paulwal
    I used my gopro knockoff, a Yi Action Cam, and it looks like mostly the transmission mount is bouncing around. I think I'm going to replace that mount and the carrier bearing.
    Anyone have any experience with these carrier bearings?
    SKF
    Beck/Arnley
    DEA/MRC
  6. Sep 23, 2017 at 7:42 PM
    Glamisman
    Glamisman Well-Known Member
    while you are under there grease all of the u-joints and the driveshaft slider/extender "IF" equiped.
  7. Sep 23, 2017 at 7:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    See what @gunny1005 can get you for an oem one from Camelback Toyota. I've heard bad things about all aftermarket cb's.
    gunny1005 and mtip like this.
  8. Sep 24, 2017 at 5:19 AM
    newintowntoo
    newintowntoo New Member
    Don't overthink this just grab the grease gun and grease your driveshaft and universals
    billybop90 and mechanicjon like this.
  9. Sep 24, 2017 at 6:32 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    X3
  10. Sep 24, 2017 at 8:54 AM
    Badmood
    Badmood Well-Known Member
    Leawood, KS
    2000 Lunar Mist TRD
    It's axle wrap. Rear springs are weak, my truck used to do the same thing.
    Crew Dawg Dave likes this.
  11. Sep 24, 2017 at 9:59 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    If your rear springs haven't been changed then it could be axle wrap, but lube the driveshaft first (it's cheap). Don't just throw parts at it unless you are a lot wealthier than most of us.
  12. Oct 2, 2017 at 7:13 PM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Sounds very familiar to mine. Doesn't happen all the time, but I have took note. I will have to check for loose motion at the carrier bearing soon. Keep us posted on what you figured out. 2006 2nd gen...
  13. Jun 28, 2018 at 5:53 PM
    TT03
    TT03 New Member
    2021 SR5 Tacoma 4X4
    I have a 2003 Tacoma 4X4 V6 TRD 5 Speed Manual Transmission, Extended Cab Long Bed. I had same issue. I found that I had one dry universal joint on the rear drive shaft next to the transmission. This is a double universal with three grease fittings. I noticed it had not been greased at the dealership where I had them lube in the past. I lubricated the universal with my grease gun by pushing out all the old dark grease until new grease came out. I wiped it off and drove it. It made a slight clunk as I began driving then stopped, never heard it again. I located all the grease fittings and lubed them all three on the front drive shaft six on the rear drive shaft nine total. Be sure to use grease made for a Tacoma.
  14. Feb 12, 2021 at 6:20 PM
    Stevemazumas
    Stevemazumas New Member
    2004 Tacoma prerunner
    Did you ever figure out what was making the clunking noise?
    I have the same issue.
  15. Feb 12, 2021 at 7:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    more than likely axle wrap.
  16. Feb 15, 2021 at 3:41 PM
    doityerself
    The Deep South
    2006 SR5 DCLB 4x4
    I would suggest greasing all of the driveshaft fittings and changing gear oils. Then change transmission fluid and filter. Mine went away after doing that.
  17. Feb 15, 2021 at 10:19 PM
    Madjik_Man
    Colorado Front Range
    Check out Timmahs! Videos on the slip yoke also.
    Dalandser likes this.
  18. Feb 15, 2021 at 10:33 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    90% of the time the “clunk from a stop”
    On these trucks is the telescoping section of the rear driveshaft, AKA slip yoke clunk. Locate the grease fitting about 2 feet forward of the rearmost u-joint and pump more grease than you think it needs into it, more than likely the clunk is gone..
  19. Feb 16, 2021 at 7:22 AM
    badboypro
    badboypro Well-Known Member
    Sunnie
    Pittsburgh, PA
    1997 Tacoma SX
    I also agree it's probably the carrier bearing/transmission mount, but dropping in to share my experience:
    I also had this issue, but I also 'felt' (and not heard) a tiny clunking when I shifted from Park to D or R or any gear (I have an auto). The clunking was definitely worse when coming to a stop, and intermittent. My solution ended up being replacing engine mounts and transmission mount, which sounded scary but ended up being a reasonable cost. My driveshaft and rear axle were okay. So maybe also check out those two engine mounts?
  20. Sep 21, 2022 at 11:14 AM
    Fossilguy14
    Fossilguy14 Member
    2003 tacoma
    Hi All.
    I have a Tacoma 03 SR5 V6 4WD 4 Door. I only use the 4WD in snow here and there and in the Outer Banks a few times on the beach. I also feel the clunk intermittently when i come to a complete stop when the truck settles back or when i start to move forward again. I had the carrier bearing replaced although the old one didn't look to bad , just in case that helped.It did not. It had some grease on the Spline. The transmission motor mount was tightened up a little, seems OK. I haven't had the rear springs checked out yet. Axel wrap ? Motor mounts split in the hard Rubber ?
    I just had a mechanic at a garage that I've been going to for years take a look. Very reputable always satisfied. He took it for a test drive and says its most likely a problem with my transmission ? So I'll go to the transmission shop they recommended (a 5 star shop) to have them check it out. I would imagine they will also check mounts and the drive shaft as a whole.
    Before I do that has anyone else found it to be a transmission problem ? No other noises besides the thunk at full stop or when I start back up. on occasion. Nothing other than that.
    Just made an appointment with the transmission shop . In a week or so. will see what they have to say. Will follow up on the forum with results from first visit.
