Clunk When Steering - Lower Control Arm
Discussion in '1st Gen. Tacomas (1995-2004)' started by peterpadlock, Dec 14, 2017.
  1. Dec 14, 2017 at 2:35 PM
    peterpadlock
    peterpadlock [OP] Active Member
    Virginia Beach
    2002 Tacoma 115k
    3'' OME lift - 881 & Toytech AAL kit 265/75R16 Procomp AT tires Procomp La Paz wheels
    Tacoma World...Hello.
    Lets get some facts out of the way first....
    2002 Tacoma, just lifted it ( 3'' OME 881s, and AAL) - work was done by 4wheel parts - this is key.
    when they did the work, they knew the lower control arms would be seized up, so they said they would burn/cut the old ones out and be replaced by new shiny ones - expensive, but- its a 15 year old vehicle... F#*k it...
    so the lift was done and I couldn't be happier.
    2 weeks later
    clunking while steering and stopping. Actually causing the truck to shift a little...scary. Can't be the control arms I say... they are brand new!!!!
    IT IS!!!!!
    Video here is the passenger Lower Control Arm, rear mount ... its clear something is up.
    let me hear it guys~
    ill call them and see what i get.
    Jerry311SD likes this.
  2. Dec 14, 2017 at 2:37 PM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    Oh, and they burned both of my Inner Tie Rod Boots...
    cool.
  3. Dec 14, 2017 at 11:01 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    If you can drive and capture that would be better. you are putting a lot of load directly to the LCA by cranking the steering wheel left and right. you will definitely get movement. almost sounds as if the noise isn't there and somewhere else.
    try driving down your street or a back road and get the "scary" movement. plus what's that around the cam bolt washer? looks like part of the bushing?
  4. Dec 14, 2017 at 11:33 PM
    4xtacoma
    4xtacoma Well-Known Member
    Jake
    Grass Valley Ca
    00' sr5 trd 5 speed 4x4
    3 inch lift, 265 75 R16 mxt's
    Steering rack bushings/worn rack
  5. Dec 15, 2017 at 3:25 AM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    i replaced my steering rack bushings 3 months ago -
    if you look closely, you can see the LCA move fast, just when the "clunk" happens
    ill mount a camera around there while driving and see what i get.
    4wheel parts is cool about it thought - im bringing in the truck today to get it looked at - no questions asked.
  6. Dec 15, 2017 at 5:08 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    What bushings did they replace them with??
  7. Dec 15, 2017 at 8:59 AM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    Haha. I don’t know
    Probably took some styrofoam from the trash man.
    Just dropped it off - every time I go there it’s like I’m an inconvenience - only one solid dude in that entire place
  8. Dec 15, 2017 at 9:01 AM
    01GreenTacoma
    I replaced all of my bushings with energy suspension a few months back and they have almost no motion at all with the wheel being turned back and forth. That looks like a bad bushing to me.
  9. Dec 26, 2017 at 5:34 PM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    for the record - they re-torqued the LCA and no problem since -
    although now i need to replace the lower ball joints because they are leaking a little now
  10. Dec 26, 2017 at 5:41 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I have an 03. My cam nut and bolt looks totally different.
  11. Dec 26, 2017 at 5:43 PM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    i mean - i just got a lift and they said it was "seized" so they replaced everything new.... it cost some money but hey..
    now im having issues with my wheel bearking i think
  12. Dec 26, 2017 at 5:56 PM
    otis24
    Mark
    California
    It looks like maybe they didn’t replace it with an actual cam alignment assembly.
    It should look like this:
    There’s a sleeve the bolt goes through. If they just put any old bolt through it all the torque in the world won’t make it work.
  13. Dec 26, 2017 at 7:42 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    re-watched the video on full screen. it did seem like the washer was moving on the inside causing the noise. These do need to be torqued correctly to help keep the cam-bolt assembly from rotating. however that washer should be part of the bushing (washer - tube - washer), the washers are "peened" or "pressed" onto the tube that goes through the bushing
    aftermarket is always shiny and smooth :D
    It is an oblong cam sleeve, I can see it on the video. It's not a Toyota one with the markings though.
    otis24[QUOTED] likes this.
  14. Dec 26, 2017 at 8:40 PM
    otis24
    Mark
    California
    Ah! That makes sense!
    Sorry OP I hope I didn’t scare you.
    I recently had an incident where the alignment shop I went to didn’t re-torque the alignment bolts. The truck was driving all kinds of crazy. I stopped to check it and discovered the front nut was gone. The only thing keeping the bolt from falling out was the skid plate. The other nut was super loose.
    The best part was I was in the middle of nowhere in Mexico. I cobbled together some washers to fit over the sleeve and found a bolt with the help of a local mechanic. I drove it that way 700 miles to the nearest toyota dealership to get an new nut. Totally ate my tires. I had to rotate them after 250 miles because my alignment was so off.
    I don’t have much trust in shops at the moment.
    jonesbt likes this.
  15. Dec 26, 2017 at 9:07 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Didn't you post about this adventure on here while it was going on? (If it wasn't you, someone else just had this happen about a month or so ago) I'll have you know, this story has me buying an OEM set of alignment bolts to go in my truck tool kit before I go on my next off road excursion.
  16. Dec 27, 2017 at 4:38 AM
    otis24
    Mark
    California
    Yeah, that was me.
  17. Dec 27, 2017 at 10:37 AM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    thanks for all your input - the control arm seems fine now. and i do have that sleeve. everything seems fine now except for the lower ball joint..
    otis24 likes this.
  18. Dec 27, 2017 at 10:41 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did they replace your steering boots. I thought you said they burned those. If those have holes in them, that could cause expensive problems down the road.
  19. Dec 27, 2017 at 3:16 PM
    peterpadlock
    Virginia Beach
    2002 Tacoma 115k
    they did replace them - no charge of course for the work... which there shouldn't be.
    anyway- everything with that is good to go - too cold today to take a video of me spinner the wheels for a wheel bearing noise example.
    maybe tomorrow
    also - my CVT mt. Bachelor tent arrives saturday
    otis24 and El Taco Diablo like this.
  20. Jan 21, 2018 at 5:01 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Dude, thanks for this video. I've owned this truck a year and half and have always had this clunking sound. Have had three alignments done at different shops and none of them have held. The steering wheel would always go out of center.
    Just checked the torque of the LCA cam bolts. Three were way under the 96 ft/lbs and one was finger tight. Now the clunk as complete gone away.
    Cheers
