clunk when stopped at light.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wheelieking396, May 2, 2012.
  1. May 2, 2012 at 9:32 AM
    wheelieking396
    wheelieking396 [OP] Member
    06 prerunner db cab trd off road
    Ok so my 2006 pre-runner does something strange when I'm at a red light or just waiting. I'll be waiting at the stop light and then the transmission seems to jump and make a clunk like I got rear ended. Its like its settling to find neutral or??? Could it be a torque converter problem? Has anyone had this problem or heard of this? Any info would help.
    Thanks.
    Vince.
  2. May 2, 2012 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its "Axel WRap". Normal.
  3. May 2, 2012 at 9:37 AM
    wheelieking396
    Never notice before had the truck since new
  4. May 2, 2012 at 9:47 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Exactly when does it clunk? Is it when releasing the brakes? That's how my axel wrap issue happened.
    There are a number of ways to fix the axel wrap issue. I clamped my leaf springs at specific locations. That's the cheap fix.
  5. May 2, 2012 at 9:47 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    x2...mine went away for a while...not its back :(
  6. May 2, 2012 at 9:53 AM
    wheelieking396
    It sometimes happens when I release the brake and sometime just when I'm waiting to take off. Could it be a torque converter problem? I have noticed that the rear suspension sucks and it bottom out lately.
  7. May 2, 2012 at 9:57 AM
    tacowestley
    tacowestley Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    Actually same here i get it when im coming to a stop and when I let go of the brake
  8. May 2, 2012 at 9:58 AM
    wheelieking396
    Yes we are in the same boat. Do you know what it might be?
  9. May 2, 2012 at 9:58 AM
    BTO
    California
    Don't know why you are stuck on the torque converter. Everybody knows it's the leaf springs that is the cause. They start out weak and get weaker to the point the overload leaf begins slapping against the one above it. That's the clunk you are hearing.
    I think your best bet is to replace your leaf springs. That will fix both of your complaints.
  10. May 2, 2012 at 9:58 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    get some aals mine went away after i accidently installed my leafs backwards lol
  11. May 2, 2012 at 9:59 AM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
  12. May 2, 2012 at 10:02 AM
    wheelieking396
    Even when there is no load on the truck and just waiting at a stop light. would aal work or should I do something better?
    thanks
  13. May 2, 2012 at 10:13 AM
    anthony250f
    Anthony
    San Diego, CA
    it should work, i have toytec tsb aal
  14. May 2, 2012 at 11:29 AM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    I don't mean to thread jack but today I just found out that my leaf packs were squeaking on my way to school! :(
  15. May 2, 2012 at 12:11 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    :rofl:
    to the OP:
    a leaf pack may help...it did for me for a while but now its back :(
  16. May 2, 2012 at 12:13 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    my shit clunked bad for few days after every time I let go of the brakes after a full stop. turned out to be a loose lower control arm.
  17. May 2, 2012 at 2:39 PM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    :mad::rolleyes:
  18. May 22, 2012 at 9:31 AM
    H2Otx
    H2Otx The Tinkerer
    Austin
    Houston, Texas
    10 DC 4x2 SR5 TRD Off-Road
    SilverStar Ultra Headlights; Nokya Ion Yellow Fogs; SuperBright LED Bulbs; 8" Shorty Antenna; WeatherTech Mats / Bug Shield / Vent Visors; TRD CAI with aFe Pro Dry S Filter; aFe Pre-Filter; Custom CAI Cover and Fuse Box Cover; TRD AT Shift Knob (Japan); TRD Oil Filler Cap (Japan); n-Fab Step Rails; Monster Hook
    I have had the same "clunking" issue. Coming to a complete stop or when I lift off the brake just a hair. Has been happening for two years. It almost feels like a transmission downshift.
    I don't hear it as much as I feel it. Would axle wrap still cause this? Not sure what to tell the dealership to examine.
  19. May 22, 2012 at 5:16 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Mine clunked when I was stopped, normal. The other times it was just shit just moving around under the tonneau cover in the bed of the truck lol.
