Clunk when switching 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teslabolt77, Dec 16, 2012.
  1. Dec 16, 2012 at 6:55 PM
    teslabolt77
    teslabolt77 [OP] Well-Known Member
    Is it normal to hear a slight clunk when disengaging the 4x4 system? (from 4HI to 2HI)
    Also, should I engage it periodically (in a straight) to keep the system lubed if I am not using it for months on end?
    Thanks
    83k miles and counting
  2. Dec 16, 2012 at 7:13 PM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    The clunk is completely normal. Both the transfer case and the front axle can make a slight noise. As far as engaging 4hi on occasion, there is very little need. That is mostly useful on trucks with lockout hubs. When the hubs are not engaged then the differential does not spin and half of the ring gear does not get oil. Our differentials always spin.
    I suppose there might be some benefit to exercising the actuator motors so they stay free. But I would imagine that would be a minimal risk.
  3. Dec 16, 2012 at 8:08 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    I understood Toyota says to
  4. Dec 16, 2012 at 9:15 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    I just use mine whenever it rains :)
  5. Dec 16, 2012 at 9:16 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Normal!
  6. Dec 16, 2012 at 9:21 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When disengaging from 4H back to 2WD right before you turn the knob take your foot off the gas pedal so there's no load on the driveline and you won't get the clunk noise.... it will be smooth as butter. I try to make the switch either on level ground or down hill... never up hill.
  7. Dec 16, 2012 at 9:26 PM
    Spoonman
    Jamie
    Alberta
    Definitely do that^^
    Still clunks, but very minor (mine at least)
  8. Dec 17, 2012 at 9:00 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    10-4, 4x4 is the way to go and Toyota does want us to engage it monthly so when it rains or snows... or on a straight road if dry... Naturally, getting Off Road is the best!
  9. Dec 17, 2012 at 11:42 AM
    offroadwonder
    Jared
    Aurora, CO
    Apparently I need to spend more time in my user's manual. My mechanic background disagrees with this, but I do try to stick to Toyota's recommendations.
