Clunk when turning only in 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thedude101, Oct 1, 2024.
  1. Oct 1, 2024 at 2:57 PM
    Thedude101
    Thedude101 [OP] Member
    Noticed recently when using 4wd it’ll have clunk sound only when turning and only in 4wd. Anyone ever had this problem? Maybe the front diff mount(s)? Tia.
  2. Oct 1, 2024 at 3:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Depending on the surface, traction, and how tight the turn. That is normal.
    You are putting the driveline in a bind when turn in 4WD. Something has to give.
    Normally, it's ground (slick conditions).
    If the ground doesn't give, the driveline does.
    Thedude101[OP] and TheWildMan like this.
  3. Oct 1, 2024 at 3:21 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Ouch.
  4. Oct 1, 2024 at 8:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Don't operate in 4X4 unless you're on a slippery surface where the tire can spin slightly on the ground when cornering. Loose dirt, gravel, grass, mud, snow ice etc. Even wet pavement isn't a good idea. And even then, avoid making tight turns. Shift out of 4X4 if you have to unless the ground is slippery enough that you cannot move in 2wd.
  5. Oct 2, 2024 at 3:25 AM
    Thedude101
    Always been on sand or mud when I use it (only time I use it). Never use it on pavement I know it’s not good for drive train. Just noticed it’s done it recently when on sand couple weeks ago and muddy fields yesterday
