Clunk!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Braindead, Sep 5, 2015.
  1. Sep 5, 2015 at 8:54 AM
    Braindead
    Braindead [OP] Well-Known Member
    JoJo
    Atlanta
    02 PreRunner
    I have a 2WD auto V6 2002. When I stop, I get a clunk. Universal? What?
  2. Sep 5, 2015 at 9:12 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Could be anything. Is it coming from front, rear, do you feel it in the steering wheel, under you butt. Could be tie rods, rack guide, rack bushings, ball joint, broke leaf spring, transmission mount. If I'm just guessing you are saying as you are slowing down when the truck down shifts to first gear? Mine does this, and I have replaced u joints, but not carrier bearing, but greasing the joints if it's aTRD seems to stop it.
  3. Sep 5, 2015 at 9:16 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    My 98 PreRunner clunked everytime I stopped too.
    Someone said it was because the drive line was so loose.
    :notsure:
  4. Sep 5, 2015 at 9:32 AM
    TACO TX
    Kelly
    Denison ,Texas
    My carrier bearing is a little loose and the Trans mount is a tad loose. May swap the Trans mount out soon, I have quite a bit of movement in the shifter during start and stops.
  5. Sep 6, 2015 at 10:20 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like axle wrap to me.......:notsure:
  6. Sep 7, 2015 at 12:21 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Grease your rear slip yolk, it's Tacoma axle wrap, completely normal for these things unfortunately. You can buy leaf spring helpers and install them upside down to fix it, or add beefier leaves to the rear is another option. I grease mine every oil change, but I am going to do the leaf spring helpers modification next payday for sure. Only costs like $30 to buy the parts and is an easy DIY job.
  7. Sep 7, 2015 at 12:22 AM
    2004TacomaSR5
    Jon
    Montana
  8. Sep 7, 2015 at 6:39 AM
    TACO TX
    Kelly
    Denison ,Texas
    I have brand new leaf packs and still does it periodically.
  9. Sep 7, 2015 at 10:54 AM
    2004TacomaSR5
    Jon
    Montana
    How many leafs? 5 is ideal from what I hear, the stock 3 wont really make a big difference.
  10. Sep 7, 2015 at 12:33 PM
    TACO TX
    Kelly
    Denison ,Texas
    Wish I had of gotten the heavy duty packs, so may not make much difference. :frusty:
  11. Sep 9, 2015 at 7:56 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Thanks for the info!
