Clunk?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ResearchMonkee, Jun 26, 2019.
  1. Jun 26, 2019 at 7:46 AM
    ResearchMonkee
    ResearchMonkee [OP] Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Hey all.
    Couple months ago, I went to perform an oil change on my truck. I'm sure you all know where this is going now.
    :bananadead:
    I did the research (obviously not well enough) and watched my friend drain his. (obviously not observant enough) While underneath, I was scoping the truck to make sure I got the right pan, another friend stated it was the ATF pan which I drained from for like 1 minute before I plugged it right back up. I could not tell you how much I drained as I already had fluid in the oil catch pan from a previous job. Should have just looked at my phone again instead of relying on his word. My mistake. Attempted to fill back up, trunk starts clunking mildly on stops and go.
    Took it a Valvoline shop cause cheap pricing and a hopefulness that they can square it away. I told/asked them if they were familiar with the weird way to test the ATF levels to make sure accurate. They assured me they did. (they didn't as I suspected) They filled it up, but I don't think it's the right level it should be at.
    The clunking on stop and go is driving me nuts. Am I right to think that it is most likely the incorrect fluid level and that I need to do the OBD jump to ensure proper level? I was going to attempt to grease up the slip yoke in drive shaft as I have found on several thread suggestions.
    Any tips/suggestions would be great.
  2. Jun 26, 2019 at 7:52 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Do a full drain and refill. That’s really the only way to be sure the level is correct
    ResearchMonkee[OP] likes this.
  3. Jun 26, 2019 at 8:37 AM
    ResearchMonkee
    Derrick
    KCMO
    That's what I'm thinking.
    Seems 4-5 quarts are needed, maybe an extra just in case.
  4. Jun 26, 2019 at 9:18 AM
    TimKnocker
    TimKnocker Active Member
    Be careful. I'm pretty sure AT does not drain the full 4-5 quarts. Do not overfill the transmission. Is there a Dipstick for the Trans or is it one of those sealed AT systems Toyota is doing?
  5. Jun 26, 2019 at 9:19 AM
    ResearchMonkee
    Derrick
    KCMO
  6. Jun 26, 2019 at 9:21 AM
    TimKnocker
  7. Jun 26, 2019 at 9:21 AM
    ResearchMonkee
    Derrick
    KCMO
    Thanks, gonna need it.
    Doesn't seem too bad to do, just time consuming.
  8. Jun 26, 2019 at 9:25 AM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    ^This
    I think it also depends on if you have an oil cooler(like a little mini radiator, mounted in front of your main radiator), which can make a full drain/refill a little more of an ordeal. So, an ordeal on top of an ordeal. Whatever you do, definitely verify it is at the required fill level by going through the process you seem to already be familiar with(jumping the two ports to verify it is at correct operating temp, etc...). Keep us posted on what you find.
  9. Jul 7, 2019 at 3:24 PM
    ResearchMonkee
    Derrick
    KCMO
    Update: clunk is gone. ATF was overfilled.
    rmorse, TnShooter and b_r_o like this.
  10. Jul 9, 2019 at 12:10 PM
    TimKnocker
    Glad you figured out the problem OP!
