Clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, May 4, 2020.
  1. May 4, 2020 at 11:06 AM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    So recently I have developed a clunk sound coming what sounds like the driver side wheel well area when...
    turning right (Not every time)
    Going in or out of driveway aprons that have higher then normal lips (again not every time)
    And hit speed bumps at a faster then snails pace.
    I currently have it up on jacks and nothing is loose and there’s not much play in anything and my front driver side tire doesn’t wobble like it’s the wheel barring
    only thing I have noticed is both my wheels when free spin sound like there is some sort of debris or something in the break pad area or axel area. Like maybe I didn’t fully spray the wheels down enough after the last outing.
    any ideas on the clunk sound?? No other noises when going down the road.
  2. May 4, 2020 at 1:28 PM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
  3. May 4, 2020 at 1:29 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    If it’s not sway bushings or end links. Probably lower control arm bushing sleeves seizing or radiator mount bushings.
  4. May 4, 2020 at 2:12 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had a clunk, it was my lower control arm bolts and nuts, they were loose. When you check these, have your truck on ramps if you can. You want the weight of the truck on the suspension if/when you tighten them. I use a 2' cheater pipe on a 1/2" drive ratchet. You should probably use a torque wrench and you'll have to remove your skid to get to them.
    This got rid of my clunk, but it could be a number of things.
  5. May 5, 2020 at 3:57 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'm going w/ LCA ball joint.
