Clunking after installing 887 w/5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Jan 16, 2021.
  1. Jan 16, 2021 at 9:56 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    Is clunking normal after installing 887s with 5100s?
  2. Jan 16, 2021 at 10:11 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Check you sway bar and make sure it's not hitting the coils. Did you install the sway bar relocation mount?
  3. Jan 16, 2021 at 10:11 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    No. Could you give a few more details? Did you do the install yourself? Was it aligned afterward? Does it happen when you're going over bumps? When cornering?
    One thing I would suggest is putting it up on some ramps so the front suspension is at ride height. Remove the front skid, mark your alignment tabs then loosen the lower control arm bolts and retorque them. They need to be torqued to 100 ft*lbs. Do the same for the lower strut bolts. If I recall correctly, the front bushings are loosened by the bolt head and the rears are loosened by the nut.
    Also, check your top strut nuts and your sway bar connections.
  4. Jan 16, 2021 at 10:13 PM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    Clunking after hitting bumps?
  5. Jan 17, 2021 at 9:59 AM
    jsnm23
    2011 mgm TRD OR 4x4
    I think it's the sway bar hitting the coils on the driver side. I need to get the sway bar relocation brackets.
