Clunking after new 887s with 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Jan 24, 2021.
  1. Jan 24, 2021 at 7:49 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    I've been thru everything after installing the new springs and shocks. Everything is tight but I can't get rid of this clunk when I hit bumps at at around 10mph or more.
    Are 887s too long for the shock causing them to bottom out (or top out, however you look at it)?
  2. Jan 24, 2021 at 8:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Did you install a sway bar relocation?
  3. Jan 24, 2021 at 8:05 PM
    jsnm23
    2011 mgm TRD OR 4x4
    I haven't but I would imagine if the sway bar were hitting the coil I would see a blemish mark on either one or both but I don't. Albeit the sway bar on the driver side has like 1/8th inch clearance from the bottom coil seat.
  4. Jan 24, 2021 at 8:07 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    May I suggest disconnecting the sway bar and seeing if the clunk subsides?
  5. Jan 24, 2021 at 8:10 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Which c clip ring did you put the spring plate on?
  6. Jan 24, 2021 at 8:12 PM
    Whiskey21
    Whiskey21 Active Member
    2018 DBLCB LB MGM
    Frame mount bushings (?) supposedly known to go bad fast.
